what are my gauge options
Old May 5, 2005 | 08:56 AM
scarecrow's Avatar
Muted User
i am long overdue for gauges i am gonna go with fuel pressue ,egt ,boost. does anyone make a digital setup for a 2001 or do i want normal gauges. if so any special make
Old May 5, 2005 | 09:13 AM
HOdiesel80's Avatar
I believe someone makes a digital gauge for your truck. Don't quote me on it, I don't even know who makes it. I have heard that they are a pain to read though, since all your readings are on the same gauge. I don't like the idea of looking at my gauge reading for an extended period when I should be keeping my eyes on the road. In my opinion the regular gauges are easier to read, just a quick glance is enough. I installed Diprocal white faced in mine last week. My only complaint is the bulb doesn't keep them well lit, enough to read though.
Old May 5, 2005 | 09:47 AM
jfpointer's Avatar
Nordskog makes individual digital gauges for EGT, boost, and fuel pressure. Mine are on order right now. They do have a 0-30 psi fuel pressure gauge, but it's not currently shown on their website.
Old May 5, 2005 | 02:41 PM
Cowhand's Avatar
SPA Technique.....I'm running boost/EGT and trans temp/oil temp. Had 'em for 3 years and I'm pretty happy with them, but they are $$$
Old May 5, 2005 | 03:15 PM
CTD NUT's Avatar
I prefer good old mechanical gauges with some dials!
Old May 5, 2005 | 03:28 PM
hotdram's Avatar
I think there is a brand called Dakota Digitals. Ask Big Blue about the digitals he ran and why he took them out.
~Rob
Old May 5, 2005 | 04:24 PM
mkubacak's Avatar
Go analog. I like the Isspros.
Old May 5, 2005 | 04:45 PM
RamBob's Avatar
Be a 21st century ANALOG MAN!!
Isspro makes a nice gauge called the EV (is that what you have MK?)
I have Autometer Sport Comps mounted on the pillar - standard black faced, red dial, perfect back lighting - matches the other gauges on the dash so there's no focal or optical adjustment necessary when switching views.
Old May 5, 2005 | 05:01 PM
jfpointer's Avatar
You have them on the pillar? I was worried about making that huge pillar even bigger by putting gauges up there, so I got the Autometer dash pod. From looking at the Spas, it seemed like they might be a little tough to read if I put them way out there in the middle of the dash up by the windshield.
Old May 5, 2005 | 06:02 PM
mkubacak's Avatar
Rambob,
Yes EV's. I should have stated that. Only Isspros worth getting.
jfpointer,
My gauges in the pod line up with the steel a-pillar almost perfectly. No extra obstuction. It may be partly because I sit with the seat all the way back. I have a pic in my gallery made before I repainted the pod with the factory color.
Old May 5, 2005 | 06:28 PM
Mopar1973man's Avatar
A picture says a thousand words!
I did the DiPricol white face... The needle is easy to see day or night.
Old May 6, 2005 | 08:23 AM
RamBob's Avatar
Nice set up, Mopar - what's that wet stuff on the window?
Here's what you need Scarecrow!
Old May 6, 2005 | 08:48 AM
Sometimes I think I'm in Oregon...
Like I said a picture is worth a thousand words! - Thanks for the coment RamBob...
Old May 6, 2005 | 09:25 AM
WildBill's Avatar
BD X-monitor is digital and flashes warnings at you - adjustable warning parameters, mounts on a-pillar down low so no blocking your view, and has optional adjustable cooldown timer.
Duallydog
Jan 4, 2009 10:15 AM
Rickcher
Dec 30, 2008 12:32 AM
Kawracer
Feb 13, 2007 06:30 PM
Flatty
May 20, 2005 12:43 PM
