What does it feel like
Old Jul 27, 2007 | 06:40 PM
SFA's Avatar
SFA
what does a slipping clutch feel like, I hear everyone say that their clutch is slipping. What does it feel like and when does it generally do it? I am sure mine has to be doing it with my TST comp on 9 and my stock 5speed with 138K on it.
Old Jul 27, 2007 | 06:48 PM
Mountaineer's Avatar
It feels like your not going any faster even though your truck sounds like it is.
Old Jul 27, 2007 | 07:00 PM
SFA's Avatar
SFA
So, would the RPMs stay the same and motor rev? In 4th gear usually when I hit around 2k rpms my truck will kinda rev, rpms stay at 2k or fall slightly then they pop back up and I am off and running again, does this sound like clutch slipping?
Old Jul 27, 2007 | 07:01 PM
can17's Avatar
Not sure what you mean by "RPMs stay the same and motor rev." Your rpms rise but you don't move any faster, almost like revving it in neutral. A clutch slipping is kinda like losing traction. Your tires start spinning faster but your not moving. FWIW, my brother has a TST Comp + Smarty on his truck and so far (8,000 miles) his stock clutch has held it.
Old Jul 27, 2007 | 07:08 PM
clutch1's Avatar
a sliping clutch will cause the rpms to rise and the speed to slowly catch up if it ever will.
Old Jul 27, 2007 | 07:10 PM
kas83's Avatar
My tach jumps up, truck doesn't accelerate at all. If I let off too quick, which has happened, it'll bark the turbo. You know when the clutch is slipping, trust me.
Old Jul 27, 2007 | 07:26 PM
phox_mulder's Avatar
An old timer once told me a good way to test your clutch.
Pull up to a tree, wall, building, or other immovable object, so your bumper is touching it.
Put transmission in 4th gear, let out the clutch.
If engine continues to run, you have a bad clutch, it is slipping.
If engine stalls, you have a good clutch.
I added this 3rd option myself:
If immovable object starts moving, you have a Cummins.
phox
Old Jul 27, 2007 | 07:30 PM
SFA's Avatar
SFA
OK, I have had it slip a few times then, but I do have the problem not about my rpms dipping when I really get into it with my TST on 9 in 4th gear when my rpms "stall" or dip at 2k then rise back up, what could that be
Old Jul 27, 2007 | 07:42 PM
clutch1's Avatar
is it just the tach dipping or do you actually feel the rpm drop?
Old Jul 27, 2007 | 07:57 PM
BBA's Avatar
BBA
Yea im pretty sure you will know when your clutch slips. My clutch does not slip until i get into 6th gear and lug it and im on a stock clutch.
Ghearic
17
Sep 3, 2011 05:56 PM
texasredrider
Sep 7, 2006 04:56 PM
99 cummins
Mar 14, 2005 03:00 AM
TurboPirate24v
Aug 1, 2003 02:11 PM
crossy
Dec 3, 2002 06:02 PM
