What Do You Think Of These???
Old Feb 23, 2006 | 12:56 PM
STACKED's Avatar
Question What Do You Think Of These???
Went and checked the codes and got some that im not sure what they mean, can you help me out.
p0463 fuel level circuit high input
p0237 turbo boost sensor A low
p0253 injection pump fuel metering control low
p1688 metering oil pump stepping motor circuit malfunction.
p1693 turbo charge control circuit malfunction
The truck barely starts now and i want to fix it. the guy who checked them said this is the most he has seen on a truck that runs.
Old Feb 23, 2006 | 01:21 PM
BigBlue's Avatar
0622-Generator Field Not Switching Properly
0743-TC Clutch Solenoid/Trans Relay Circuit (Lock up switch)
0500-No Vehicle Speed Sensor (Explains ABS lights)
1492-Ambient/Battery Temperature Sensor Voltage To High
1765-Trans 12v Supply Relay Ctrl Circuit (Lockup Switch)
1694-No BUS Messages Received From ECM Module
1693-DTC Cleared In Companion JTEC Module
0236-MAP Sensor To High To Long (Plugged the map sensor back in)
1693-DTC Cleared In Companion JTEC Module (no I didn't write it twice)
0501-Vehicle Speed Sensor Performance (ABS light again)
0602-ECM Fueling Calibration Error (MAD ECM???)
That's my list and my truck runs like a champ. That 0253 code looks like a dead injection pump which would explain why your truck ain't running.
Old Feb 23, 2006 | 01:44 PM
STACKED's Avatar
Yeah thats a long list, but they dont sound as bad.
Old Feb 24, 2006 | 03:16 PM
STACKED's Avatar
Thanks for all the help.
Old Feb 25, 2006 | 05:16 AM
Ph4tty's Avatar
Wow, 7" tip eh? I don't think I've ever seen one. I'm no help either
Old Feb 25, 2006 | 11:46 AM
STACKED's Avatar
local chrome shop, had a 7" 45 for a big rig, 75.00 dollars. still getting alot of looks and laughs. im glad its not two wheel drive or it would hit and drag on everything.
Old Feb 25, 2006 | 08:03 PM
tomgreentwin's Avatar
7"
Man, get a pic of that 7" tip! I'm waitin' on my 5" tip that will arrive on Monday.
desertram800
Dec 12, 2006 10:40 AM
OldSmokey
Oct 19, 2006 08:05 AM
yfz450guy
Sep 10, 2006 11:08 PM
PeteRR
Aug 20, 2004 07:34 PM
Shaders 24v
Feb 20, 2004 05:54 PM
