What could i be missing???Twins question.
OK heres the deal I just installed a B2 steriod turbo and my stock hx-35. The instal went ok just took quite some time but its all worth it i thought. So here is the deal I can only make 12 pounds of boost! Its like i have a bad boost leak ( i did at the very beggining an dnow that one is pixed). I have checked my truck over for the leaks the best i can and nothing. Is there anything i should look for that i cant think of? This is my daily driver so i would really like to get this fixed pretty soon. I mean i can drive the truck it just really feels like a dog! Any help is appreciated!
Kevin
Kevin
I had the same problem while I was installing my twins. It turned out to be a combination of a few things. First I had a few boost leaks, a few leaks in the hotpipe, and in my case the wastegate on the hx35 wasn't opening at all trying to force all the exhaust through the small charger. What is your drive pressure like? I hope you get this figured out.
Joe
Joe
A wastegate stuck open could cause poor performance at low speed but should feel more normal at WOT (well over 12 psi). Hot pipe leaks would produce lots of soot under the hood and should be easily spotted.
If your sure there is no boost leak (would have to be serious leak), I would look for poor air flow??
JMO - RJ
What is the A/R on the exhaust housing? How big is the turbine wheel. I tried a Garrett charger as a primary it had a 1.1 A/R turbine housing and I couldn't get that thing to make more than 10lbs of boost. No boost leaks in the system and with everythign else checked out. I discovered it had a huge turbine whell on it something over 4 inches (can't remember exact size). I also had a s400 on the bottom that I couldn't get to spool because it had a 1.33 A/R turbine housing. I don't know if this helps just something to check on.
Joe
Joe
I vote for exhaust leak or cracked exhaust manifold. I hate exhaust leaks. It make my hood all black. Boost leaks, it would have to a really bad leak. You could hear the leak. The wastegate might be stuck full open and your just on the primary. If its stuck, its just takes for ever to light both turbos. It happens but laggy.
I had a big boost leake and got it fixed and cant find anymore now? It has a Tier wastegate on it. I also dont know anything on this wastegate. So does this help anymore at all?
OK i think i have figured out the problem. I will know tomorrow because thats when i can get to it but i dont really know how to explain it right now. I have not seen where the wastgate is opening yet but that was my next step. Which is where the whole problem i think i have figured out is. I will try to explain it to the best of my knowledge. Ok the top turbo (stock Hx-35) there is the little piece on it like where the wastgate opens? It needs to be pushed one way to keep it closed. So we tacked it there and the genious that was helping us apparently had a few to many and said it need to be one way which in fact was wrong.So now i have to take the tack off and push it to the side it should have been on the first place............ok sorry i know that made no sense to yall but i tried. I will try and get some pictures tomorrow.
