What Box Can i Stack With Edge Comp?
Old Oct 22, 2005 | 10:38 AM
Sea01Cummer's Avatar
Injecters and a 35/40 Hybrid are on the horizon this spring , what box can i stack or can i stack with the edge comp. Possibly the Catcher? Sorry for the stupid questions but i am the rookie here.
Steve
Old Oct 22, 2005 | 10:51 AM
dodgediesel4x4's Avatar
There's not much you can stack w. the comp since its a timing and fueling box. A Mad ecm would be a great combo, maybe a tad hot for that hybrid on higher settings. Now if you want a great/timing box combo, get a VA and stack it w. the comp, just leave the comp in ez mode (untapped). You will have the adjustability of the VA for fueling (9 levels) and 5 levels for timing w/ the comp.
Old Oct 22, 2005 | 12:21 PM
oestreich84's Avatar
I think dodgediesel4x4 meant the tst pm3. The pm3 is a strictly a fueling box, which will work great with a timing/fueling box such as the comp. With this combo you will need to get a clutch upgrade a turbo upgrade, and a fuel system upgrade. The catcher, from what I have read from other posts, will give you awesome bottom end, but with the comp it wont help out much on the top end. Another way to go would be to get a set of injectors. Just do a search for injectors and pick out which ones fit your budget and your needs.
Old Oct 24, 2005 | 01:24 PM
Yep, I meant PM3 . A few beers later and after a dissappointing Stros' loss, I realized that.
szwayka111
Sep 18, 2007 09:35 AM
bwarning01
15
Aug 24, 2007 09:19 PM
dodgediesel
Jul 27, 2007 08:59 AM
whitestreak06
Jun 8, 2007 01:29 AM
hellotbone
Jul 12, 2003 12:58 AM
