What The????
Old Oct 20, 2006 | 07:26 PM
dodgediesel's Avatar
Angry What The????
Had my motor rebuilt about 10k ago. I was just running my comp box 5x5 and I could peg the pyro. Loaded smarty on #8 and comp on 5x5. It feels like my power has gotten less. I can barely hit 1250 on the pyro.. What's up with that? Also sometimes my comp box does not light up when I start my truck so I have to turn it off and start it back up.. I just had the comp repaired about 6 months ago. Is it time for a TST 3 Comp??? I'm not sure I wan't a box with no on the fly timing, any suggestions out there...
Old Oct 20, 2006 | 07:33 PM
judge88's Avatar
could be your vp pump. something to check
Old Oct 20, 2006 | 07:35 PM
blackdiesel's Avatar
Registered
pull the codes. And you oughtta switch your edge comp to the tst comp anyways because its so much better!!
Old Oct 20, 2006 | 07:48 PM
My HRVP is 4 months old and I have a constant 11 psi fuel pressure...
Old Oct 20, 2006 | 07:53 PM
Registered
some new pumps do go out even tho they have sufficent fuel pressure
codes????
Old Oct 20, 2006 | 08:13 PM
judge88's Avatar
heat will kill vp's just as quick as low fuel pressure.
Old Oct 20, 2006 | 08:24 PM
How does a guy test out his vp to see if it is still good??? Oh yeah, I live in Canada, i wish it was warm!!!
Old Oct 20, 2006 | 09:40 PM
Tiger Rag's Avatar
Your Comp could've gone bad. It does happen with them periodically.
Old Oct 20, 2006 | 11:30 PM
Tate's Avatar
Take it to a dealer or a diesel shop. They unplug the ECM from the VP, and plug in a Cummins test tool, which will diagnose electronic problems. GCL in either Edmonton or Calgary (not sure which part of the province you're in) should be able to do this. Don't bother with NADP, they will just farm it out. They said they do bolt on parts, and can't do any diagnosis.
Old Oct 21, 2006 | 02:41 AM
kelownadiesel's Avatar
check the ground and the tap wire .
