went from 215's to DDP4's!
Thanks.
Paul
Paul, the end cap on the AFC cover (where the AFC diaphragm can be accessed) has an allen headed set screw with a lock nut. I think you have to remove a little cover to access it.
when I got the truck, J&H had put a lot of pre-load on it for Dusty to help reduce smoke. I was concerned about limiting rack travel (still gotta get a longer AFC spring!) so I set it up so that the set screw was just touching the shaft... zero lash essentially.
my adjustment when I put the injectors in was pretty unscientific, I just ran the allen screw in about 1/8". I can still put out a heck of a cloud if I floor it, but part throttle is VERY drivable, and I don't even have to watch my mirror.
My AFC foot is also ground flat and ground back maybe .050-.060" at the shallowest point (lowest)
the back of the foot I cut like 1/2" off and chamfered the hole... it'll never hit the back of the cover now!
ambient conditions make a heck of a difference...
I was seeing 1400* when I first installed these things... at 54* ambient in Oklahoma I was seeing 1300*... I'm at sea level down here south of Houston, and at 42* ambient, max EGT's in 6th gear was 1200*!
pmtg
Nov 18, 2007 11:28 AM
Captain
13
Oct 1, 2007 09:13 AM
