went from 215's to DDP4's!
when I swapped the twins for an sps62, I messed up the threads on one of my DDP4's, so I installed some 215's w/ thick washers... tons of idle haze, smokey, truck made 48psi, EGT's rarely saw 1200*. this was with the fuel rack resting on the stock front plug.
retorqued the studs up to 120lbs and installed the 4's today... anticipating a smoke show, I put ~1/8" pre-load on the AFC shaft and took the star wheel from full forward to contacting the spring. it'll bellow a black cloud if you romp it, but it's actually easier to control than it was before! in 6th it's making 55psi w/ 50psi drive pressure, I didn't see the EGT's go over 1400*, and MY GOD does the turbo hit like a freight train now! [coffee] wish list: another 1000rpm and a 5sp [redface] |
Originally Posted by Forrest Nearing
(Post 1265722)
retorqued the studs up to 120lbs and installed the 4's today... anticipating a smoke show, I put ~1/8" pre-load on the AFC shaft and took the star wheel from full forward to contacting the spring. it'll bellow a black cloud if you romp it, but it's actually easier to control than it was before! in 6th it's making 55psi w/ 50psi drive pressure, I didn't see the EGT's go over 1400*, and MY GOD does the turbo hit like a freight train now! [coffee] wish list: another 1000rpm and a 5sp [redface] Thanks for the post Forrest! makes me wanna go pawn stuff to get the DDP 4's in, Im sure they are a nice kick over 370s as well, What DVs u runnin on them? Rick |
Thats the setup I was looking at.. I was looking for reviews on the SPS62, I really like that unit and if it reacts like you say, I will have to ask Santa for another Visa...LOL..
I think Jeff said he picked up like 60hp over the 370's w/ his twin setup... I'm just running the 181 DV's
I just had a little scare! after all that, I pulled in to get fuel and saw oil dripping under the truck! :eek: started freaking out, and headed home... figured the worst I did was maybe blow the side cover seal. turns out I pinched the back valve cover gasket [laugh] [laugh] [duhhh] |
(Post 1265948)
thanks, it feels so much better! that oil leak had me sweatin' bullets, I'm supposed to drive to Oklahoma and then back down south of Houston after xmas! :eek:
Originally Posted by thekidfan
(Post 1265979)
40hp/120tq over 370's....to the ground! Congrats on getting some fuel back to her bud!!
that was with HX40/HT3B twins
got any idea what teh ddp4s would give me over the 435s?
DDP4's are rated as a 140HP Injector, as well as 435's. They would probably just run/drive a tad better and have a iddy-bitty less smoke... But thats just speculation... lol
yeah, proably not enough diff to warrant a change...
I've got a good client up in Magnolia! :D |
(Post 1266026)
Actually PDR 40 and PDR 3.5B more air then the standard 3B |
Forest,
Did you get a deal on your DDP4's? I want a set but can't afford $899. |
they were in the truck when I got it, but I've heard them selling for around $700, not sure where though.
Originally Posted by Hemi Dart
(Post 1266694)
Forest,
What did you do with the lenny's stage 4 injectors?
DD |
