Water/meth nozzles
Old Dec 19, 2006 | 09:12 PM
Joker12valve's Avatar
Water/meth nozzles
The kit came with a 600cc nozzle, can i go bigger? How big, and what psi do you start spraying. I was thinking a bout adding a second stage of injection with a larger nozzle. mabye a nother 600cc at 30psi. The egts slow down at frist then rise fast, i would think that a nother stage at 30 psi would keep me from injection to much water. What do you think? thanks
Old Dec 20, 2006 | 08:51 AM
RowJ's Avatar
What's your primary usage? 30 psi for second stage is ok for WOT racing, but king of useless if towing on the Hwy.
What kit? My Snow's 2-stage is set to start injecting at 18 psi. Ramps up to full at 40 psi. Anything below 18-20 psi can quench the fire if using washer fluid or straight H2O. At least that was my experience when I had a single turbo.
RJ
Old Dec 20, 2006 | 04:37 PM
mainly racing, what are your nozzle sizes? I will be adding a second tank fora more agressive mix, was reading around and it sounds that some kits use 2 625 nozzles. if that is true i need to go even bigger then i thought.
Old Dec 20, 2006 | 08:57 PM
Got....Diesel?'s Avatar
I use Snow...and I have 2 of their 625's and one 375 at full pump pressure (220 psi, though not really when it's flowing)....all on one stage, and on at 40 psi. 50/50 pure meth and water. It's just a playtoy for me.
Old Dec 21, 2006 | 03:01 PM
RowJ's Avatar
Yup! Two 625 nozzles here also. Standard issue from Snow's....for diesels.
Rj
Old Dec 21, 2006 | 06:02 PM
I have a nother 600cc nozzel on the way and a 400cc on the way for the 2nd stage along with the hobs switch will let you know how it works out, as long as the trans holds,
DUKCALN
Jan 14, 2009 09:19 AM
jdpiii
Jun 19, 2008 07:34 AM
LanceD
Oct 29, 2007 01:54 AM
LanceD
21
Apr 6, 2007 09:31 AM
BigBully
Feb 16, 2005 06:19 PM
