Water Meth kits
Water Meth kits
I'm interested in a water meth kit for my truck, i hear it will lower my egt's as well as give me some more jam, I'm looking for pro's a con's. The kit looks like something a guy could build him self
Jack
Jack
I've used the Snow's stage 2 and 3 for the last 3 1/2 years and was a tester for the stage 2. The stage 3 has no cons. Works exactly as advertised. The stage 2 is very close. No other modification will decrease egts, save a turbo, like water injection does. None.
How fast do you burn thru the fluid? I was thinking about this too, but after talking to the local shop and hearing that they burn up a gallon in about 30 sec.'s I decided that it wasn't practical....
Originally Posted by Willy91
works great for me to.
I like it a lot, but honestly if it wasn't on the truck when I bought it I wouldn't bother getting the stage three, at least not for my application even when towing heavy in valet mode it doesn't even kick in, I've got plenty of air to keep it cool, but if you have problems with egt's it would be a great system for towing
I suppose the worst problem with the stage 3 is where to mount the box. Very difficult to make a professional installation.
In towing situations it is a quantum leap in performance over the stage 2 system because of the smoothness of delivery.
....after talking to the local shop and hearing that they burn up a gallon in about 30 sec.'s I decided that it wasn't practical....
At the drag strip, I get 6 passes out of a gallon, or about 60 sec.
RJ
I read a post by "loch" on building up a water/meth injection system, has anyone followed his instructions and how well does it work? Is there a benifit from buying one, or can I build one that will work as good? My only concern would be the quality of the spray nozzle....
Originally Posted by INJECTOR JACK
I'm interested in a water meth kit for my truck,..... I'm looking for pro's a con's. Jack
The H20/Meth Kit will give more "JAM". 500 HP trucks pick up 40-60 HP. (That's with 50% Racing Meth fuel...not just washer fluid.)
I love the system...used it mainly for EGT control....got 150-200* lower in mountains and towing.
The only con I have encountered is at WOT, for example Drag Racing. The temps may climb a little slower but they do not, in my expirience, level off lower. IF I back off the throttle, like on the hwy, they will drop down....AND stay down. But for some reason they will not peak at a lower temp while still holding the peddle on the floor? May just be my truck??
The only other cons...not biggies, are
1)after using, you must remember to run your truck for a while to eliminate any water vapor still in the cylinders. I used 5 min as overkill, but suspect 1-2 min is enough!
2) Takes patience and some testing time to set it right... for your usage. Not just a plug & play mod.
The pros far outweigh the cons, IMO. Very helpful system for anyone with EGT problems, and fun to have.
RJ-Stage 2 Snow's Kit
Originally Posted by rjohnson
Jack,
The only other cons...not biggies, are 1)after using, you must remember to run your truck for a while to eliminate any water vapor still in the cylinders. I used 5 min as overkill, but suspect 1-2 min is enough! 2) Takes patience and some testing time to set it right... for your usage. Not just a plug & play mod.
H20 Meth
I just installed a pdr hx 30 with 14 cm, #10 plate 3 k afc spring & a full 4"
I have the plate foward .20" If i do full blast it heats up quick on the pyro but backs down on the temp right away when I let off, i'm worried when I put the camper and the boat on what's going to happen, That's why i'm looking at the water meth system. By the sound of it I should spend the money and by the kit.
Thanks for the info guy's....Jack
