Water/meth cooling
Water/meth cooling
I have the coolingmist for diesel, (non egt version) and i put in the 2 nozzles in the intake horn... it doesnt seem to help with cooling, i havent tried meth yet, but we did try with only water and water/alcohol 50/50 mix.
do i need a bigger pump or more or bigger nozzles?
EDIT? i emant to post this in the 3rd gen forum, however its the same, i guess. i see about 1450 degrees max on the 06
im running a 375 ml nozzle and it slowed down the climb but if i go to a bigger nozzle I will run my 7 quart res, out as it is now on a handful of short hard pulls i have less then 1 quart left at a 1/4 tank fuel. might need a 5gal. tank now
jrussell
Jun 24, 2009 09:24 PM
jdpiii
Jun 19, 2008 07:34 AM
Roperteacher
Jul 9, 2007 11:28 PM
