water/meth ON
Originally Posted by storx
i purchased a 55 gallon barrel from local exxon fuel warehouse for like 144.00 and i mix it up myself. Mine is a 2 liter container so i dont know much about the kit you have with 2 quarts. But i mix it about 50/50 and i can actually feel the difference when it kicks in i have mine set at 34psi because that is when my EGT start to peak over 1k at wot. Then the second injector kicks in at 50psi.
Originally Posted by blackdiesel02
im running to 625 jets. and i dunno how to turn up the pump pressure.
I only saw 3-4 psi boost gain, even with racing meth, when I first installed mine...on a big single turbo. Noticable 'push' when it comes on... but not a neck snapper!
Both nozzles work from the get-go! The pump just 'ramps up' to full pressure at the max setting.
Mine is plumbed into the Washer Fluid bottle ... gives you one gallon, AND a low level warning light
RJ
well im not sure its 2 quarts. i just know i can pour half a gallon in it and its full. i go my standard units not that crazy metric stuff
What??
2 quarts and a half gallon are the same thing. What metric stuff??
The purple colored TroubleFree brand windshield washer fluid found at Advance Auto Parts is 45% methanol and on sale for $1.68 a gallon if you're in a pinch.
I can definitely feel a BIG improvement in performance though it doesn't bang as I run with the variable controller. A big jump in spool-up from the starting point to limit. Much improved acceleration.
Had anyone ever heard of runing rubbing alchohol instead of methyl? I have a buddy, believe it or not, you will crack up. He took the hose that supplies the windshield washer fluid nozzle and cut a hole in the intake tube, and just stuck it in there. He hits the wipers and it shoots a direct stream into the pipe (rubbing alcohol) and he says he can feel a good amount of power when he hits it! I rolled!!! It looks exactly as you are picturing, just a rubber hose sticking in a slit right before the turbo... But back to my main question - rubbing alcohol?
i cant see any adjustment on the pump??
RJ
I dont think the fast spooling turbo's will find that much of a difference in the setup water/meth but ther bigger turbo guys like me that have a noticable lag off the line feel a huge difference.
When I first installed my W/M system with a single nozzle and used an 80%/20% mix I couldn't tell when it was working at all. Since I couldn't feel it I installed a couple of LED's to tell me when it was on and off.
Since then I've added a 2nd (very large) nozzle and increased the pump pressure to max. Now I get a good 8-10psi jump in boost when it hits and there is no doubt it's on and working. The engine and turbo get MUCH louder and I can feel the truck accelerating faster than usual. I've also switched to a 55%/45% mix and that seems to give a lot more power than 25% or less of meth.
Here's a recent post from the 1st gen forum with some video clips of my boost gauge with and without W/M: Link
The hobbs pump is the same as my variable controller pump. it is adjustable.
RJ
Originally Posted by rjohnson
You got me curious... and I had 2 other questions... so I talked to Snow's.
RJ
RJ
i figured brandon would have had it turned all the way up!
where are yall gettin your meth at? im going to quit running ww fluid, they say that i will get a noticable kick in the pants with the real deal.
Where are yall gettin your meth at? im going to quit running ww fluid, they say that i will get a noticable kick in the pants with the real deal.
Works very well.
