Water Injection results
Old Sep 17, 2003 | 08:58 PM
Jim Fulmer's Avatar
Seems after talking about what I've done with this some of you still wonder how good it will work, well I have some new data for the lower H.P guys.
Truck in question, 97' 5 Speed Dually with 185K on the clock, specs...#10 equivalent plate, 3K's from Piers, Stock DV's, Stock Injectors...STOCK turbo with a 16 housing from Piers, 4 inch Exhaust, Timing bump and Snow Performance Stage 2 Water Injection, and a Southbend Clutch. At the start some 2 months ago the truck was at 170/351 and was set as a baseline, with the above mods and my tuning, power is at 375/901, EGT's on the dyno were 1600 and boost was 35 on the road EGT's were real high(should have seen it with the 12 housing :'() now for the water on, EGT's on the road were 1450-1475 at 110 MPH, on the dyno they were 1400 boost at 40 psi....now the power, Matt Snows kit made 70 hp and 110 ft/lbs using a 50/50 mix of Water/Methanol that pushed the power to 446/1008. So for those of you that still question or still doubt I have added the dyno sheet for you amusement, Thanks to Matt for the system and Chuck at Alternative Motor Sports in OKC for both the truck and the dyno to test and tune at
Jim
Old Sep 17, 2003 | 09:25 PM
darloa's Avatar
Re:Water Injection results
Those are amazing numbers, Jim. Who would have thought that water could make horsepower and so much. I guess the methanol probaly helps. What much does a water system like that run. I might consider one for my truck, since I can peg a 1500 degree pyro in about five seconds or less.
Old Sep 17, 2003 | 09:28 PM
Battering Ram's Avatar
Jim, How fast can you get one to my door?
Old Sep 17, 2003 | 09:39 PM
StakeMan's Avatar
How much water and where was it injected?
Can water be a drug?
Old Sep 17, 2003 | 09:46 PM
Don M's Avatar
DTR Advertiser
methanol is!
Don~
Old Sep 17, 2003 | 09:58 PM
Great... now me and my truck are both going to have to go to the AA meetings.
Old Sep 17, 2003 | 10:08 PM
Mostwanted's Avatar
Does water work better than nitrous? I was told that nitrous does the same as the water injection, is this tru? If so, which is better?
Old Sep 17, 2003 | 10:26 PM
dsljunkie's Avatar
Does the water/methanol have any of the negative effects on your truck like the NOS ???? If so, how severe ?
Scott
Old Sep 17, 2003 | 10:38 PM
DeereDiesel's Avatar
Hey Jim,
How much boost did you have it set at to turn the water on?
Thanks
carty
Old Sep 17, 2003 | 10:52 PM
Jim Fulmer's Avatar
Reply's
1. Darloa...$400.00
2. Horace...One Week from Matt....I'm not a dealer
3. Stakeman....about 1/2 gal/min in the hat
4. Don....power and cooling
5. Horace...yes
6. No Nitrous is better...IMO
7. DSL.....I've had my head off since running water and all it does is clean the pistons
8. On Chuck's comes on at 8 psi and is full on at 25 psi with the controller.
Jim
Old Sep 17, 2003 | 10:56 PM
Jim,
Does running this system clean up smoke or create more? Or is there a difference in smoke runnin straight water vs water/meth?
Thanks
carty
Old Sep 17, 2003 | 10:59 PM
StakeMan's Avatar
1/2 gal per minute at 35psi
Old Sep 17, 2003 | 11:27 PM
Jim Fulmer's Avatar
Deere...more smoke from the meth....it never cleans up.
Stake...it likes it.
Incanus....Matt has more data now from me, everything I test he knows...real good people to work with, and he is following this thread.
Jim
Old Sep 17, 2003 | 11:28 PM
StakeMan's Avatar
Guess I will have a new toy to tune for next years racing season. ;D
