Walbro 392 Kit
Old Nov 2, 2006 | 07:28 PM
CTD01's Avatar
Walbro 392 Kit
I was looking at the walbro 392 kit and i was wondering if it came with the regulator? If not where do you get one? Also if I buy the kit do you need the big line kit? Thanx,
Paul
http://www.glacierdieselpower.com/pr...?pf_id=3929852
Old Nov 2, 2006 | 07:39 PM
slim51015's Avatar
Yes it comes with a regulator. Its to the right of the big hose clamps in the link pic.
Old Nov 2, 2006 | 08:12 PM
CTD01's Avatar
Walbro
What does it regulate the pressure to? TIA,
Paul
Old Nov 2, 2006 | 08:22 PM
pind's Avatar
Mine sits at a rock steady 18 psi at this point. I have heard from 17 to 20 psi on the 392 kit.
Also, no pressure drops noticed, which is truly a bonus. Best bang for the buck that I have been able to find.
Old Nov 2, 2006 | 08:30 PM
CTD01's Avatar
Line size
Is this with the lines that come with it or the big line kit?
Old Nov 2, 2006 | 08:33 PM
Ridiculous's Avatar
deffinetly a great buy. i got mine on my truck for several months now.
yes it comes with literally EVERYTHING to install it, no joke.
no, you do NOT need the big line kit(i don't have it) but i plan on putting it on later on down the road.
if you order it, i recommend order by phone! i think the guy's name is rich, (not for sure so don't quote me on that) but you will see that he is such a great guy, he told me that if i have any questions i could call him at midnight it doesn't matter. great man. i did have a little problem with getting the wrong wiring harness and it also had a bad relay, but he took care of me, and it wasn't his fault either. the relay was the company who makes the relay's fault, and the wiring harness was just too long, it was for the 03-05 not my 02, but he sent me all new stuff next day delievery free of charge!
mine sits at a rock solid 17 psi, and i can't drop it below 15 psi at WOT. also he can ship you shims for the regulator that will increase the psi, he'll talk about them if you order by phone.
so in my opinion...buy it and don't look back...great instructions too.
Old Nov 2, 2006 | 08:36 PM
CTD01's Avatar
Walbro
Thanks guys for all your help,
Paul
Old Nov 2, 2006 | 08:42 PM
mcctho21's Avatar
Definately just buy it. I conjured one together but I wish I would have just bought Rich's kit. Great guy. Helped me even though I didnt buy all my stuff from him.
Old Nov 3, 2006 | 08:39 AM
2500CTD's Avatar
I have one too Not from GP, but got it it from wideopendiesel.com I'm having good luck with it. So I like the walbro conversion, and widediesel helped me out in that I had the intank pump as well.
Old Nov 3, 2006 | 05:53 PM
piperca's Avatar
If I'm not mistaken, this is the AFS kit, correct? I'm running that system too ... nothing but good things to say about it!
Old Nov 6, 2006 | 06:35 AM
2500CTD's Avatar
I'm pretty sure we have the same kit. Except dunno if you have/had the intank or not?
Just read ur sig, you got the Draw Straw not the Draw Straw II like me.
Old Nov 6, 2006 | 07:07 PM
jriggs_18's Avatar
I too am looking at the walbro kit but I have the intank pump now, So if I buy the walbro kit will i also have to buy the draw straw? Will I have to remove the intank pump and only use the Walbro, or do you use both pumps?
Old Nov 6, 2006 | 09:40 PM
Joe Mc's Avatar
Paul
Just tell Rich you want the big lines he'll set you up with the correct fittings and everything you need. As far as "what does it regulate?", it's off the dish side of the pump before the filter so it keeps the psi in check buy returning excess through the regulator to a mainfold that dumps into the tank fill tube. Everything comes with the kit. I waited 5 long Carter POS LPs until I had enough and saw the Glacier product - didn't want the FASS - MPO
Old Nov 6, 2006 | 09:42 PM
Joe Mc's Avatar
I'd ditch the in-tank and go w/the Vulcan straw. If the in-tank goes and binds up will you burn up the walbro in the process??? Why chance it - another $50 garuntees you'll never have a flow issue and get that POS in-tank where it belongs - in the trash. MHO
Old Nov 7, 2006 | 08:28 AM
mbfarms's Avatar
You can always put in a Draw Straw II. Cheaper than replacing module.
http://www.wideopendiesel.com/Vulcan...Straw%20II.pdf Install Instructions
oaborbag
Mar 3, 2008 09:27 AM
Sixpack73
14
Oct 14, 2007 11:04 AM
Texaschevelle
Sep 12, 2007 09:34 PM
streetsmoker
24
May 7, 2006 12:26 AM
Dodge Demon
Feb 27, 2006 06:47 PM
