Vulcan Performance
Get that sucker installed! I odered my Relocation kit, but had it setup for a Holley blue pump. Everything should be installed wed. I'm just having a hard time finding a blue pump locally now!?!?!
INSTALLED!!!
Pressures went form 12-12 1/2 @ idle, 10 1/2-11 @ cruise and 9 1/2 @ WOT, to ... drum roll please ... 15 @ idle, 13 @ cruise and 11 1/2-12 @ WOT ... Eric, you're the man!
I'd like to add one additional step to the install instructions; RECHECK ALL CLAMPS
I have a nice clean engine bay. Thanks to my son for noticing or I might have run out of fuel.
I ordered mine directly from Eric, and received it 2 days later. I installed it yesterday. Good install, but I couldn't get enough room between the tank and the first stock hose line clamp to istall a ball valve. I ended up moving it approx 12" closer to the front of the truck. I relocated the lift pump-it is definitely a better place than on the block. It ends up that the pump is up above the skid plate for the transfer case.
Thanks Eric!
Mike
Thanks Eric!
Mike
JARHEAD
Mar 20, 2008 08:37 PM
Dinner
Feb 13, 2008 04:40 PM
Soffitguy
Jul 5, 2007 11:21 PM
