VP44 Pump Cover
Old Feb 23, 2007 | 07:08 PM
clinton81's Avatar
Question VP44 Pump Cover
I recently purchased An Edge EZ Pulse, Wich wires into the computer on the pump. I also recieved a new pump cover with this I have not hooked it up yet but would like to and am not clear on the instructions. Looking for help
Old Feb 23, 2007 | 10:04 PM
johnsjas's Avatar
There are I believe 4 tamper proof torque bits that hold the cover on (bd stealth cover?). There should be a bit in the kit with your cover. You will have to remove the intake. Remove the screws and replace it with the new cover. Once the new cover is tightened down take the pointed set screw and start screwing it into the cover. Make sure the key is on and your checking for a 12volt signal on the screw. Once you get the 12volts turn the screw another 1/2 turn and you should be all set.
Hope this helps.
Do not go too deep with the set screw or you chould break the circuit board
Old Feb 24, 2007 | 12:56 AM
Charlie8301's Avatar
Dusty Ratcliff
May 23, 2006 10:05 PM
CTD2001
May 4, 2005 11:21 AM
suzukiZrider
Jan 13, 2005 08:20 PM
Commatoze
0
Oct 15, 2003 12:33 PM
BluDiamond
17
Jan 28, 2003 07:01 PM
