Van Aken V5
Old Jul 21, 2006 | 05:28 PM
jhood12's Avatar
Van Aken V5
Ok so Ive heard good things about Van Aken just wanting to know about the Van AKen V5 box....What HP is it rated at.....Does it compare to the Edge Comp..... Also how smokey would the box be on a stock 02???
Old Jul 21, 2006 | 06:22 PM
jhood12's Avatar
no one has experience with the V5
Old Jul 21, 2006 | 06:27 PM
Bob Wagner's Avatar
Both these van Aaken SmartBoxes™ increase power by 60hp and torque by 159lbs ft at 2000rpm.
Old Jul 21, 2006 | 06:34 PM
Dieselcamper's Avatar
I think the Van Aaken V5 is the best towing module
available. Power seems to come on stronger and at
a lower rpm than the others.It also seems to have
a milder timing advance ,so you don't get the timing
hammer "engine rattle " that you seem to hear about
with other modules. It works great with RV275 injectors.
Seems to be the best towing combination out , according
to alot of people in here.
Old Jul 21, 2006 | 08:36 PM
Timberman's Avatar
I've got one, I like it. Got it for towing, on most folk's advice from this site. The v5 really woke my truck up, and helped quite a bit with towing a 10,000 lb trailer. It ate my stock tranny, or helped the cummins eat it, and I put in a DTT and some 1.6's, and the difference is night and day. I think it could pull the bottom out of a ditch now, it doesn't use half as much effort to pull that trailer around. Just plug the v5 in and forget about it, no adjusting or messing with it. For speed or racing, you might want something else, although it is a big improvement over stock.
Old Jul 21, 2006 | 09:19 PM
MadDog01's Avatar
I have to agree with Timberman, A Va and 1.6's are the way to go. Oh I don't have the 1.6's yet! But it won't be long!
Gary
Old Jul 21, 2006 | 09:39 PM
jhood12's Avatar
well I still have a stock clutch so im not really wantign to throw some sticks in just yet....I was looking for somethign that performed like the Edge Drag Comp....Adjustable and I can have a lot of power and smoke on demand but I can turn it down whenever I want.....Im still thinkin though...
Old Jul 21, 2006 | 09:59 PM
The Van Aaken by itself won't hurt your clutch. My stock
clutch started slipping when I added the RV275 injectors.
I do know that an Edge Comp will destroy a stock clutch
if used to it's full potential
Old Jul 21, 2006 | 10:23 PM
jhood12's Avatar
well im not worried about my clutch going out like right after I put a comp on...I know it will go out eventually but im sure it will be fine for a bit..my buddy has the same setup with me and has had a Drag Comp on his for a year now and his clutch is just now starting to slip....I just dont know if I want injectors cause as much as I like the smoke I dont want it all the time....
Old Jul 22, 2006 | 09:37 AM
Timberman's Avatar
Well, I do have to say that I was not at all kind to the stock tranny, I hammered on it all the time. Now I hammer on the DTT all the time. It is kinda nice not to adjust anything with the v5, all the power is there if you want it, or you can just drive it easy. The mach 1.6's are very clean, I only get a puff of black before the turbo spools, or if I mash it suddenly, there's a puff. You wouldn't have to worry about too much smoke with that combo, not sure how another box would affect it though.
Old Jul 22, 2006 | 05:39 PM
jhood12's Avatar
whos sells the mach injectors?
Old Jul 23, 2006 | 05:22 PM
MadDog01's Avatar
Jhood you can find them at F1diesel.com
Gary
Lrdchaos
Aug 4, 2016 10:43 PM
Andrew k
Jun 5, 2005 08:58 PM
gdh11
Jun 4, 2005 04:26 PM
ram350013
Apr 29, 2005 08:59 PM
Body Mechanic
Mar 16, 2004 02:04 PM
