Valve Springs
i understand that, but when the exhaust valve is closing the piston is chasing it, i know on or pulling tractors you have to be very careful or they will hit the piston, you can change the centerline as little as a degree and make contact with the piston, and depending on the cam grind the intake valve opens usually just a little bit before tdc.
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
12valve
Mar 11, 2008 10:57 AM
95turbo4wd
Dec 12, 2007 05:59 PM
