Valet Switch
Old Apr 22, 2007 | 10:49 AM
74dart's Avatar
Valet Switch
What is this valet switch and how do you hook on up on the old mechanical pumps.
Old Apr 22, 2007 | 11:54 AM
65fury's Avatar
a valet switch can be made many different ways, basically it cuts off boost to the afc, i takes the fuel plate out of the fueling process, for better mileage or less smoke or to cool egts, i made one from an air solenoid that i bought at napa and its hooked to a switch in the cab, a boost line comes from the intake to the soleniod then out the other end of the solenoid to the afc, and bingo a valet switch.
jason
Old Apr 22, 2007 | 12:40 PM
clutch1's Avatar
did you really see better mileage with it? they do help cut egts down while towing
Old Apr 22, 2007 | 01:37 PM
Eradan's Avatar
The valet switch cuts air to the AFC (boost). The AFC is designed to travel forward once it see's boost and add additional fuel, the valet stops it from fueling after it see's boost (ie. lower power)
Old Apr 22, 2007 | 02:47 PM
TheBigNasty's Avatar
How much of a difference will it make, because if it is a huge difference I have an idea. Lets just say it will be like putting a TST on a 12v.
Old Apr 22, 2007 | 03:29 PM
schoust's Avatar
I just made my own with a little copper tubing and a small 1/4 inch ball valve and it works nicley! I have more power than I had when it was stock and If I want more it's a matter of flicking the ball valve under thew dash!
Thanks Vss
Old Apr 22, 2007 | 05:07 PM
Eradan's Avatar
A valet switch is not a performance enhancing mod. It's a performance decreasing mod. It's designed to have on your truck for improved mileage, lower EGT's, and in some cases improved driveability.
I never loan my truck out, or let ANYONE drive it, so i have no need for it for that reason, i merely want to improve mileage.
Old Apr 22, 2007 | 10:48 PM
I know, but if you always run it on valet then turn it back to normal, it will be performance increasing.
Old Apr 23, 2007 | 09:09 AM
signature600's Avatar
It also won't help your mileage...the only way to do that is to keep your foot out of the pedal.
It will help you drive more "smoke-free" which in some people's case's, will help mileage!
Chris
Old Apr 23, 2007 | 04:39 PM
12valve's Avatar
i found putting a pressure regulator with a turning **** in the cab bewteen the line from the turbo manifold, to the afc, very nice for daily driving!
u can have every possible high boost smoke level like that!
signature600
Feb 22, 2004 09:30 PM
engcogod
14
Oct 21, 2003 02:17 PM
gunracer1
14
Jul 28, 2003 11:23 AM
Lance
Jun 11, 2003 10:06 PM
