upgrades to a 90 cummins
Old May 9, 2006 | 11:13 PM
DoubleNicoll's Avatar
i have a 1990 cummins 4x4, 3.07 gears, auto with 250k, i want to put a custom 4 inch strait exhaust, and a k&n filter set-up on it and a #100 fuel plate but im not sure if my truck is too wore out to do that to?
Old May 9, 2006 | 11:59 PM
jeepsuck's Avatar
i could be totally wrong, but i think the #100 plate you speak of is for a different type of Injection pump than the one you will find from the factory on your 90.
Old May 10, 2006 | 07:24 AM
jughead's Avatar
90 ctd
fuel screw in 2 turns.3200 gov. spring. hx-35 turbo. aftercooler optional. it will feel like it has 2 engines under the hood.
Old May 10, 2006 | 08:18 AM
JD730's Avatar
Pretty good start, but I would substitute a HTT stage 3 compressor upgrade for the hx-35. And 250k, It probably just got broke in about 5k ago.
Jeepsuck, your 101% right, fuel plates(plates aren't they for eating off of) are for 94-98.4 P-pumped engines. 89-93 trucks have a VE pump unless someone swapped it or the engine.
Old May 10, 2006 | 08:43 AM
apwatson50's Avatar
https://www.dieseltruckresource.com/...n&onlynewfaq=1
This should get you going.
countryboy_660
Nov 3, 2012 11:11 AM
banks twinram
19
Nov 29, 2004 09:23 PM
wooff
Mar 25, 2003 05:06 PM
bkay
13
Oct 28, 2002 04:44 PM
