U-bolt around NV5600 shifter
Guys I'm working on relocating my exhaust brake switch from the rocker that came with it to a push pull that I finally found for cheap to go on the shift lever. Well here's the thing...I made an aluminum mounting bracket....shaped like an "L" to mount the switch in, and planned to put two holes in it and mount it to the shifter with a u-bolt. That's where the problem is.....Lowe's & Menards don't have anything that small (5/8" diameter I think).
Any idea where I can get one?...online maybe?
You could get a cable clamp and use the u-bolt out of that. Try a real hardware store like an Ace or a True Value. I've found their hardware selection to be much better than the warehouse stores.
Originally Posted by blackdiesel02
OR, you could get a two speed rearend switch from a 2 ton truck or school bus and use it just my .02 . check my photos thats what I did
Hey I sent you a PM.
randallp84
May 31, 2010 04:24 PM
JD farmboy
Oct 17, 2006 11:57 PM
Dieselcamper
Aug 26, 2006 11:41 AM
blackdiesel
Oct 19, 2005 11:51 AM
