Twins
As I posted previously, I will soon be recieving a performance head, O-ringed, 60# springs, larger valves and ported and polished,and a high lift, long duration camshaft. What if I wanted to go with twin turbos, I would of course fab all the plumbing myself, but if I want to run my current hx35/16cm turbo, would an hx40 work as the second turbo, or would the second turbo have to something like an HBT2?
I've got an hx50 or 55 or hy50 or 55, one of those I don't remember which, I will have to go to the shop and look at the tag. Will a turbo off a big truck work, that would be easy to get ahold of, I do have access to a big rig salvage yard free parts for the pickens for me, the owner is a friend of mine. Went and looked, it's an hy55.
Originally posted by 600 Megawatts
A 40 is way too small as the bottom turbo. A 55 is getting close, although still a tad small. HT3B is probably the most common bottom turbo using a 35 on top and makes a very nice combination.
KP
KP
Also, if you stick with a 35 turbo on top, consider a smaller housing for the HT3B. The 26cm housing is most common, but smaller ones are available.
Also-- wastegates for BOTH chargers is a good idea. An external on a small housing HT3B should give a lot of flexibility.
Justin
kind of off topic
hey hohn, could you direct me to a pic (or explain) the gated 3b? i've heard little talk about this, but am in need. i'm going to be adding a external to my manifold in the near future and might as well do that too. thanks
dave
dave
Sorry, no pics because I don't know of anyone who's done it yet.
But why is a wastegate a good idea on the top turbo only? Of COURSE it's a good idea for the big charger, too.
This allows a smaller housing on the 3b. This brings the big charger in much sooner. This means faster boost and more fun, without having your twins DIE on the top on like a small housing typically will do.
Spoolup of a 21 housing with the flow of a 36-- what's not to like?
You're gonna need a HUGE gate for the big charger in order for it to be effective. Think 44mm is MINIMUM.
JMHO
JMHO
you will have some time in the piping, the oil drains and the exhaust is a pain to fit also. i thought the same thing, i have since built 2 sets and they both turned into a lot more work than i thought.
