turnbuckle on wastegate
Old Feb 26, 2004 | 09:42 PM
phox_mulder's Avatar
The turnbuckle will keep the wastegate completely closed.
If it is loose enough to allow it to open any, it will fall off and then won't work very well.
You can use the turnbuckle in conjunction with a tight spring to allow the wastegate to open a little, and keep the turbo from over boosting and destroying itself.
There used to be a pic of that setup floating around here as well, but once again I can't seem to find it.
Basically like the setup pictured,
but there is a spring between the one end of the turnbuckle and the wastegate arm.
phox
Old Feb 27, 2004 | 04:22 PM
mooseman's Avatar
thanks guys , ithink i understand what to do now and how it works so im off to the hardware store for turnbuckle and a handfull of various springs.
thanks again, mooseman
Old Feb 27, 2004 | 04:34 PM
Originally posted by dieselcrazy
is this turnbuckle thing a 24v trick ?? if so why doesnt it benefit a 12v ?? thanks, scott
You don't need it because you can just pull the boost line of your wastegate actuator and plug it to accomplish the same thing. The newer trucks have a steel tube directly from the compressor to the actuator, so the turnbuckle is the easy way to hold the wastegate closed.
Old Feb 28, 2004 | 09:49 AM
roadranger's Avatar
Guys, just be carefull turnbuckling the wastegate on a stock turbo if you've got bigger injectors.
With big injectors, the boost can get over 35 psi, which is the limit for the stock HX/HY35 turbo.
Running the stock turbo at 42 psi boost has been known to grenade them.
Also, on the hard lined HY35 turbos on the automatics, you can effectively disable the wastegate by inserting a SPENT .22 cal. shell in the tubing line, blocking it.
Do NOT use a live round in the turbo!
Old Feb 29, 2004 | 12:11 AM
rangerst's Avatar
thanks billg, raodranger, et al.....STY
Old Mar 3, 2004 | 07:03 PM
mooseman's Avatar
if anybody cares i built my own turbo master for $3.75. set my boost at 30 psi on the button. its fully adjustable from stock 20 to all it will push
thanks, mooseman
Old Mar 3, 2004 | 07:07 PM
thanks, mooseman
Build a better (cheaper) mousetrap and the world will beat a path to your door.
phox
Old Mar 4, 2004 | 09:08 AM
BOILERMAKER's Avatar
Mouseman,
I care and would love to see how you did it.
Old Mar 4, 2004 | 09:39 AM
Tengu's Avatar
Hey BOILERMAKER Ummmm.......I think it's MOOSEman! and I am very interested in this also.
Old Mar 4, 2004 | 11:41 AM
Bocifus's Avatar
Moose - Mouse, now that there is funny, I don't care who you are.
BTW, I'd like to know, MOOSEman, as well..
Casey
Old Mar 4, 2004 | 01:35 PM
oops, I didn't mean to misread your name, MOOSEman.
Hope I didn't offend you.
Old Mar 4, 2004 | 05:11 PM
mooseman's Avatar
nothing offends me boilermilker (just kidding). ill try to figure out my new digital camera and post some pictures.
mooseman
Old Mar 6, 2004 | 09:05 PM
mooseman's Avatar
still trying to get that **** camera to work.
thanks. mooseman
Old Jul 11, 2004 | 09:57 AM
CRT's Avatar
CRT
Well, I just read this post 3 times to make sure I was getting it right. VERY GOOD INFO.
I am thinking , get the turnbuckle & springe set up is what I am looking for.
Old Jul 11, 2004 | 12:47 PM
FastSS's Avatar
is this safe with a comp edge?
