Turbos
Old Jan 20, 2006 | 10:18 PM
eric13's Avatar
Turbos
What is a good turbo that isnt the most expensive one on the market for the truck in my sig.? I am looking to get my EGT's down. I know anything is better than the HY that is on there.
Old Jan 20, 2006 | 11:35 PM
heavyboostin's Avatar
I would think seriously about modifying the transmission before doing any more mods. With going with a larger turbo or larger exhaust housing you will lower the egt's, but in most cases add some power and i bet your trans, if it stock is at its limits already with just the box let alone the injectors. But for your app, you could step up a little to an hx35w with a 14cm exhaust housing, or go with a 35/40 hybrid. I think with your current mods that there is no need to go with much bigger than that.
Kevin
Old Jan 21, 2006 | 10:54 AM
eric13's Avatar
Well , my trans already took a dump on me before the mods so its already done the right way,no worries there now I want to lower EGT's thanks for the input though.
Old Jan 21, 2006 | 11:11 AM
dieselhawg's Avatar
I think the cheapest way for you to go would be a hybrid.A 35/40 w/ 14w exhaust housing.Dodgezilla makes one for around 1000.I think High tech turbo builds their own for less.They would work very good for your application.
Old Jan 21, 2006 | 11:20 AM
BigBlue's Avatar
An HX35 should probably keep that setup cooler. I ran the comp/275 combo for about a month and then upgraded to the KSB-1. But that's a very expensive upgrade. I'd say go with either a hybrid or the hx35 (factory turbo on the stick equipped trucks). One of those two should keep you cool and not blow your budget.
Old Jan 21, 2006 | 12:23 PM
eric13's Avatar
Thanks guys. Anyone with an auto made the switch to the HX 3I can get one but didnt know how much it would help.
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
1320
30
May 31, 2003 01:01 AM
4x4
Mar 11, 2003 10:40 AM
