turbo spooling ?
Old Mar 29, 2008 | 10:26 PM
coonhunter723's Avatar
turbo spooling ?
do i have enough fuel to spool a 64\14 turbo
Old Mar 30, 2008 | 02:49 AM
12valvesmoke's Avatar
sounds like it to me... you also got alot of airflow by the looks of your sig so more fuel would never hurt
Jared
Old Mar 30, 2008 | 02:51 AM
i take that back id go smaller JMO
Old Apr 1, 2008 | 10:04 AM
sledneck1's Avatar
Does this mean your 62/14 doesn't cool what you have right now?
Old Apr 1, 2008 | 03:29 PM
Tate's Avatar
If you are facing high EGTs right now, you might want to consider going to a 71mm turbine instead of the 65 you have now. You will lose some low end with the bigger turbine, but it won't choke as early either.
Old Apr 1, 2008 | 06:36 PM
Ph4tty's Avatar
Adding to what Tate said a 64/14 would be a step back in the turbine department because they clip the turbine wheels on the 64/65 to prevent surging. Big fat nevermind if you meant 64/71 like a super b special.
Advice might be better if you could say why the 62 you have isn't working out. The short answer is yes you could spool a 64.
Gambino
30
Jun 10, 2015 10:16 AM
kepi
Jul 25, 2009 10:18 PM
twvette
Nov 21, 2006 01:09 PM
1ST GEN.
Mar 6, 2005 06:59 AM
racermatt2606
Jul 9, 2004 02:02 PM
