Turbo Noise after Silencer Ring Removal
Old 01-17-2019, 12:26 PM
Jacob Nunemaker's Avatar
I have a 2nd gen 24v Cummins (98.5). I removed the silencer ring, and it made a huge difference. The turbo is so much more noticeable throughout all the RPMs, but now, whenever I am in the mid 2000 RPMs, the turbo whistle turns more to a rumble/deeper whistle. It doesn't even sound so much like a whistle at that point, I don't even know how to explain it other that a rumble mixed with a lower whistle. Is this normal after removing the ring? It happened immediately after removing the ring. Hopefully there was no damage done.
Old 01-17-2019, 01:09 PM
KATOOM's Avatar
Removing the silencer ring does nothing but allow for a little more turbo whine. What you may be hearing now is what the turbo sounds like when you're "under the turbo". Its sounds like the turbo trying to spool but a much lower tone since there's not enough rpm to create the necessary airflow. If you have a manual transmission then this is most likely the sound you're hearing now.
Old 02-23-2019, 04:59 PM
SIXSLUG's Avatar
I had to put mine back in....sore neck, tire smoke, twisted driveshaft etc
peddlebike (07-25-2019)
Dhvrd45
0
11-16-2018 03:03 PM
ace roper
01-12-2010 09:59 AM
kwpatton
07-17-2006 08:41 AM
BlackSheep5
37
01-28-2006 07:12 PM
StrokeThis2500
12-31-2005 05:19 PM
Quick Reply: Turbo Noise after Silencer Ring Removal
