Turbo and injectors for towing
Old Aug 10, 2007 | 12:41 PM
killed300ex's Avatar
Wondering what everyone would recomend for a turbo and injector setup to help with towing? I tow 14-18k a couple times a month for 2+ hours at a time and would like to have as much power to tow it with as possible(Not that it cant tow it anyways) But I already have a #6 fuel plate and 3k gsk I want to be able to lay into it on the hills without having to back off because of the egt's. Wondering if anyone could help me on a good setup to run.
Thanks
Evan
Old Aug 10, 2007 | 12:56 PM
logskidder's Avatar
Auto or 5spd??? How much do you want to spend?
Old Aug 10, 2007 | 02:09 PM
Its an auto i am in the market for a trans right now. Once I get that in I am on a budget but hope to be able to spend around 2000 to 2500 Hopefully on the lower side
Evan
Old Aug 10, 2007 | 02:48 PM
Str8Six's Avatar
I have a friend that has a 35/40 hybrid and likes it for towing. That is a low end turbo , money wise.
Old Aug 10, 2007 | 03:11 PM
logskidder's Avatar
Do the trans....call Dave G....get one of his TCC and a valve body. Then a set of stock 215 injectors, 100 or 0 plate with a 14cm exh housing on your stock turbo....this should get you in under 2000 and belive me when I say it will feel like a different truck. Once hooked you'll want a stooped pump, honed injectors, twins, cam......it never stops.
oldblue93
Jul 20, 2010 01:34 PM
cincydiesel
Jun 23, 2007 08:39 PM
KRB
May 20, 2007 06:20 PM
caleb c.
May 16, 2005 08:24 AM
BIGOKIE
Jul 21, 2004 05:53 PM
