Turbo And Injector
Old Oct 13, 2006 | 11:51 PM
txdodge97's Avatar
Turbo And Injector
I have been told if i run an Htb2 62/14 with ddps stage 3 that this will be a good set up for towning a horse trailer and welding trailers twice a week. I just want a little more suggestions before i do this to my truck. Would a HTBG be to small for the things i want to do with my truck? I want it to get good mileage the most and still have the power to plow other people away. I am only 17 and trying to figure this stuff out done all my mods on my own so far.
Old Oct 13, 2006 | 11:56 PM
wana12v's Avatar
the ddp3's are roughly the same size as 370's but the correct pattern. I would say it would be a good setup with a 10 plate 3k springs and 16-18* timing. it may still get hot but should be very controlable and should run very well.
Old Oct 13, 2006 | 11:58 PM
txdodge97's Avatar
i was thinking about 16.5 on timing and what about the turbo?
Old Oct 14, 2006 | 11:07 AM
redstreak's Avatar
Turbo will probably work well with that setup on 16.5* timing and the Stage 3's.
Old Oct 14, 2006 | 12:57 PM
Paul Winey's Avatar
txdodge97:
I'd give Paul at High Tech Turbo a call and tell him what you have and what you want. I'm thinking that the 14 cm exhaust might be a bit too big if you're towing heavy a bit more. The 62/12 has some very nice breathing range and may be a better set up for you at your current and anticipated fueling level. Bigger isn't alway better. You can also easily upgrade later to a different housing easily and inexpensively.
Paul
Old Oct 15, 2006 | 01:46 PM
txdodge97's Avatar
ok ill do that this week after i get my band clamp i broke on my turbo fixed so my exhaust isnt shooting out under the hood.
j-dubya
16
Dec 2, 2007 09:41 AM
TorqueJunkie
18
Feb 2, 2007 03:01 AM
gablekevin
Sep 19, 2006 12:12 AM
Txsmoke
Nov 26, 2005 02:34 PM
