turbo boost
Old Dec 5, 2009 | 02:57 PM
Turbo-Dodge's Avatar
turbo boost
With what I have in my sig I was wondering what I can do to produce a bit more boost. I know my chip doesnt have boost fooler and I've kicked my boost code a few times if i get on it hard at certain times but its rare that it kicks. What can I do with the waste gate? Anyway to possibly get my turbo to spool quicker? I believe i have the HY35
Old Dec 5, 2009 | 04:52 PM
sloth's Avatar
You have to address the lack of a boost fooler or the truck will just defuel when get up to 21-23 lbs
Old Dec 5, 2009 | 06:02 PM
Tate's Avatar
You could port your exhaust manifolf to aid spool up. But you have the quickest spooling turbo short of a ball bearing unit. If you ever get a bigger turbo, you're gonna have to relearn how to drive it all over again.
You can crimp the boost signal line, you can get a j-hook or a turnbuckle that will hold the wastegate arm from moving, allowing you to make more boost.
Old Dec 6, 2009 | 10:27 AM
Jaxn51's Avatar
Having run a van Aaken for several years on my truck and 80k miles, I know it has boost fooling. I pulled out the manual on it to make sure. Your problem would seem to be with the wastegate. I have a 6-speed so it was simple. I pulled off the hose and capped the port. The most boost I could pull with the van Aaken only, was around 24. This is with an HX-35, tho'. You should be close, I would think. Your setup would require a j-hook arrangement to keep the wastegate from opening too soon
Old Dec 6, 2009 | 12:38 PM
I've pulled 26lb of boost before setting off code. But i tried the smoker switch on my rig that requires boost fooling to work an it never worked i assumed it didnt have it cause i throw a code. Im trying to see how to wire a switch in to get level 3 which i believe has the boost fooler.
Old Dec 6, 2009 | 12:42 PM
lvmknsmoke..'s Avatar
wow unless my gauge is wrong i can get 38-40 lbs with my hx-35
Old Dec 6, 2009 | 04:24 PM
Tate's Avatar
You also have more fuel. He's running a 65 hp box. You've got two 120+hp boxes stacked. I'd hope you would make more boost.
Old Dec 6, 2009 | 07:00 PM
Jaxn51's Avatar
With no switch installed, you are on level 3. The switch turns it off w/boost fooling, or with the addition of a 2-3k ohm resistor, you will have 1/2 power.
Boost fooling works in all modes.
Old Dec 6, 2009 | 08:05 PM
Then why am i throwing a code when I get up past 26lb and why cant i install a smoke switch?
Old Dec 7, 2009 | 01:42 AM
Tow-mater01's Avatar
my stocker would make 40 on a hard pull, way out of map tho, truck still pourin smoke
idk if the smoke switch workes with the aaken box ive never seen it before
97dodgeram2500
Nov 1, 2009 11:51 PM
jcarrillo
Jul 10, 2009 08:24 PM
JSCumms2000
13
Sep 24, 2008 05:46 PM
vwjunkie53
19
Nov 9, 2007 02:27 PM
Bobcat698
18
Oct 22, 2005 12:27 PM
