Turbo Bark
Old Feb 13, 2007 | 08:05 AM
adidasman23's Avatar
Turbo Bark
Is is bad for a turbo to bark a lot. My turbo does it when i let off the gas when i am heavy into it. like when its at 35psi or more. does it hurt anything and what can i do to make it stop. all i know that is sounds cool. i say my truck has gas.
-Thanks
Old Feb 13, 2007 | 08:14 AM
berner's Avatar
People say it's not hard on it but I try to not do it too much. Mine will bark shifting into O/D if I give it too much throttle just before it shifts.
Old Feb 13, 2007 | 08:31 AM
BCSCUMMINS's Avatar
Barking a turbo can snap the shaft. Your 62/14 is stronger than your stocker it can take more abuse. When it barks the turbo wants to reveres the air flow, in turn your turbo wants to spin backwards. Let out of the throttle a little easer and this should help solve your problem.
Old Feb 25, 2007 | 02:40 PM
b.white's Avatar
are u guys talkng abuot the noise that comes from your waste gate when u let off the throttle or is this a different noise that i should lisen four i have a 94 auto wit mild modz
Old Feb 25, 2007 | 02:54 PM
G1625S's Avatar
There shouldn't be any sounds from the wastegate on a diesel---no pshhht like on a turboed gasser---maybe just the sound of the turbo spooling down from the tailpipe when you get out of the loud pedal, but non-gated housings do that too. Barking is heard from the air box and sounds like 'woof woof woof' or 'chuff chuff chuff' and is caused by what others have pointed out above. Not real good for the turbo...
Old Feb 25, 2007 | 03:51 PM
b.white's Avatar
oh after taking a ride and that last info i see what u mean i thought that it was the waste gate easily mastakin if u don't know.
Old Feb 25, 2007 | 06:19 PM
Timmay2's Avatar
The only noise youll ever hear from a turbo besides the whistling is compressor surge.
This occurs when a sudden change in pressure causes the compressor to slow down drastically.
On our trucks its not a huge problem. Its more of a problem on gas vehicles and others with a throttle plate. Snap the throttle closed, the air the turbos pushin out has no where to go and "stacks up" against the compressor, creating the sound.
On diesels that dont have a throttle plate (like your 2002) You should not hear anything except turbo whistling.. even if you let off the throttle hard your turbo is still spinning like it normally would.. throttle has nothing to do with regulating airflow in and out on these trucks.
Hope that made sense to you.
TDIwyse
15
Dec 6, 2008 11:19 AM
OldRam
Feb 16, 2006 06:41 AM
MKELLY
Oct 15, 2005 10:15 AM
pwrtripls1
Jun 25, 2005 09:38 AM
gatf4
18
May 31, 2005 04:31 PM
