TST or Smarty
Old Dec 28, 2006 | 06:52 AM
ct2500's Avatar
TST or Smarty
I was looking for something else to run with my comp now that i have enough air what r u guys runin and how do u like it?
Old Dec 28, 2006 | 07:10 AM
blackdiesel's Avatar
Registered
you can't run 2 wire tap boxes at the same time, so that takes care of the tst. smarty on even # would be good, BUT I would say you need some BIGGER sticks. my.02
Old Dec 28, 2006 | 07:30 AM
ct2500's Avatar
yea i got some mony for x-mas iam gonna get 150hp nozzels. wut do u have?
Old Dec 28, 2006 | 07:52 AM
Registered
mach 6's, they are rated at 220 hp
Old Dec 28, 2006 | 12:22 PM
ct2500's Avatar
Do you have tst or smarty? Do you think that they are better than edge comp?
Old Dec 28, 2006 | 12:28 PM
aggiehorsepower's Avatar
If I were you I would go with the tst and the smarty if you have the money. It would make a real nice setup.
Old Dec 28, 2006 | 12:43 PM
Registered
i am set up with the tst pm3 comp and smarty. and i have ran the edge comp. it really isnt an even match because it wasnt a drag comp, but the tst and smarty obviously pulls harder
Old Dec 28, 2006 | 12:50 PM
haloman's Avatar
You could untap the comp and run it in EZ mode and then use the TST box but the smarty is real nice too.
Old Dec 28, 2006 | 04:08 PM
rollinsmoke's Avatar
Let me hear what you guys think. With my TST PM3 and smarty and an edge ez is that to many boxes workin against each other or you think it's helpin. If it would help what would be a good # on the smarty?? I've tried 9 before with the timmin on smarty and plus the timmin on EZ with tst and after runnin it hard it really lopes for a long time when idealing (like 1 min or longer)
Old Dec 28, 2006 | 04:20 PM
Registered
i guess you could do that if you ran the smarty on an even numbered software but i dont think you would see much of a gain. and if you did i dont think it would be enough to justify buying the other box....
Old Dec 28, 2006 | 04:27 PM
Yea.. I didnt' know, I already had the EZ so i put it on,its been on for a while now with the tst and smarty, usually on #8 with smarty, but I did put it on 9 and it definatly ideald funny after runnin it hard. Does your truck run best on 8 with the tst or a different #?
Old Dec 28, 2006 | 04:31 PM
Registered
it dynoed the best with the smarty on 9 and the tst on 6 but i still think it pulles harder with the tst on 9
Old Dec 28, 2006 | 04:35 PM
I bet once that other pump gets put on, level 9 would be a good choice. I hope so anyway
Old Dec 28, 2006 | 04:41 PM
Beeram305's Avatar
CT2500, You should try and update the comp to a drag comp before you spend ALL that money to change entire setup.
Old Dec 28, 2006 | 08:45 PM
ct2500's Avatar
How about the edge drag comp and smarty u guys think that ill work good for a while till i can save up some for the TST?
