transmission fluid ???
Old Apr 13, 2007 | 07:27 PM
taken5875's Avatar
what fluid do I need for a 47re? and how much do i need
is it dextron3.
Old Apr 13, 2007 | 07:31 PM
dzlfarmboy's Avatar
Just regular old Dextron Mericon 3 and about 17 quarts if you drain your converter to which you should
Old Apr 13, 2007 | 07:45 PM
Crimedog's Avatar
If you use Dexron you need to add a bottle of Lube Guard. Otherwise any brand of ATF +3 or +4 will work without additive. For a new tranny I believe I used a full ase of fluid when I did mine. If it is just a pan and filter drop it will be approximately 8 qts if I remember right.
Old Apr 13, 2007 | 07:56 PM
taken5875's Avatar
it is a brand new GB tranny vb and tc that I just put in 2 weeks ago and now there no fluid on the stick looks like my temp sensor leaked oops
Old Apr 13, 2007 | 09:45 PM
Don Baggett's Avatar
I'm told 4 qts for pan drop and filter change, 8 if you loosen up the valve body and drain behind it, around 16 if you drain the TC.
Old Apr 13, 2007 | 10:56 PM
wcbcruzer's Avatar
ATF +4 is what you really need, no additive. The rest is just a cheaper alternative.
Old Apr 14, 2007 | 12:31 AM
Moose10's Avatar
Not to hijack but on my '97 2.7L 4Runner, I need to change out the tranny fluid & filter again. In the past, that's all I've done. She's got almost 150k on 'er now and still running strong. Should I, and how do I drain & refill the TQ?
If it's too complicated to explain in a post, link me to a website that explains it.
Thanks guys !!!!
Old Apr 14, 2007 | 05:57 AM
jabber's Avatar
unless your TC has a drain plug and it shouldn't. You will need to pull the tranny
Old Apr 14, 2007 | 08:56 AM
dzlfarmboy's Avatar
Best bet would be to call up Dave and see what he recomends in his trannys
Old Apr 14, 2007 | 12:04 PM
infidel's Avatar
Most diesel tranny experts recommend Dex III plus Lubegard black.
+3 and +4 are just Chrysler's scam to get your money.
Old Apr 14, 2007 | 03:01 PM
BigBlue's Avatar
I'm running amsoil in mine but DTT told me I could run dexron 3 or ATF+3 if I wanted with no problems. They actually told me not to run +4 because it has more limited slip additives so to speak (that's not whats in it but the only way I could describe it) so the factory tranny's shift smoother. They said that theoretically it could cause the tranny to slip sooner than normal +3 or dexron.
Old Apr 14, 2007 | 04:18 PM
Olratlr's Avatar
is it dextron3.
With my DTT set up I am running atf+3 no additives.
LockedandLoaded
Jan 17, 2008 02:51 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
