trans temp sensor
Old Jul 30, 2007 | 06:54 PM
kelownadiesel's Avatar
trans temp sensor
ya dudes I just installed new guages in my 12v.Was debating on getting the line with the fitting or weding a bung on the pan.Where on the pan is the best?Do you guys think its wise to do it or just buy the line.whereis the best place to get the premade line.
Old Jul 30, 2007 | 07:42 PM
Danavilla's Avatar
If you weld in a "bung" in the pan, make sure the probe won't come in contact with anything inside when it screws in place. On my '98, I came very close. Can't say where the best place would be.
Dan
Old Jul 31, 2007 | 10:01 PM
cheapskate's Avatar
just buy the "T" fitting from genos garage. cut the "hot" line from trans (underneath radiator) , install "T" and temp probe, run your wire to guage and you're done.
Old Aug 1, 2007 | 02:23 AM
wcbcruzer's Avatar
I'm selling a Swagelok tee fitting for $15 shipped. Just like the one that Diesel Manor sells for $45.
https://www.dieseltruckresource.com/...=12265&cat=500
Putting the sensor in the hot line is the best and probably easier than putting it in the pan if you don't already have a drain plug installed.
Old Aug 1, 2007 | 09:54 AM
Danavilla's Avatar
I have one of the "T" fittings from Geno's in a box in my garage. If you want to pay the shipping, I'll give it to you.
E-mail me @danbavilla@wmconnect.com
Dan
Old Aug 1, 2007 | 12:14 PM
dieselfuelonly's Avatar
DTR question asker
Do you have to drain all the tranny fluid to install one of those ts or the line from DieselManor?
Old Aug 1, 2007 | 05:06 PM
wcbcruzer's Avatar
Dan
The compression Tees are better.
Old Aug 1, 2007 | 05:07 PM
wcbcruzer's Avatar
I don't think you have to drain all of it. But some will come out.
Old Aug 1, 2007 | 05:19 PM
phox_mulder's Avatar
I think I lost around 2 quarts just fixing a leaking temp probe in my line with the port.
I believe they lost 2 quarts when they installed the line as well.
phox
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
SilverDiesel
22
Aug 24, 2007 11:28 AM
NWDave
Oct 26, 2002 09:29 PM
