Trans Go Shift Kit
Old Oct 19, 2002 | 10:37 PM
scottrod's Avatar
Re:Trans Go Shift Kit
I am thinking about one myself. Does it have various kits for shift firmness?
Old Oct 19, 2002 | 11:04 PM
PapaSmurf's Avatar
Hello<br>This sounds like something I have been thinking about and talking about for my wife's truck. It has one of those slush boxes in it for a transmission. ;D :P Just kidding here those comments where not meant to offend anyone.<br><br> I would like to know where you bought it and the cost. If you can't post the information of the site could you PM and let me know.<br><br>John-P<br> Is this the same kit you used in your truck??<br><br>Thanks<br>See Ya<br>Chris
Old Oct 20, 2002 | 09:33 AM
scottrod's Avatar
Thanks Gonzo- Looks like a good way to go till I can do the whole thing ;D
Old Oct 20, 2002 | 04:59 PM
1dslram's Avatar
I have one here in my garage my Tranny let go before I could install it. If interestred let me know.<br>Bruce<br>iam1dslram@hotmail.com
Old Oct 21, 2002 | 12:16 AM
DBR's Avatar
DBR
I installed the TFOD kit with a TCS converter on our 24v 3500 at 33k for less than 5 bills and that was including the cost of the ATF. I did take my time doing the install…it took 3 half-days. First day to pull, the next day to install the kit, and the last day to reinstall. The valve body and seal work should be done early in the morning, long before you break out the beer. Shortly after the install (two days) the wife and I took the truck on a 4500 mile vacation pulling our 25’ TT through the mountains of the Northwest. We were very happy with the truck’s new character. The truck has 275’s and comp and the rest of the typical stuff. On a side note, I very seldom used the comp past level one sub-level one. Actually I ran the truck mostly with the comp off.
Old Oct 21, 2002 | 07:36 AM
98rammer's Avatar
scott, i've been looking into this a lot lately...did you feel uncomfortable grinding away at the valve body? are the line pressures a lot higher? (enough to hold the lock up clutch). i'd like a nice, firm shift, but not something that's going to snap my neck...
Old Oct 21, 2002 | 02:30 PM
DBR's Avatar
DBR
On mine, if I recall correctly, I have 86psi @ Idle, 115 psi @ wot and 138 psi in lockup. I did not drill the separator plate and the shifts are soft, which I wanted.
Old Oct 21, 2002 | 03:00 PM
Diesel Dave's Avatar
I had a Trans-go installed on my truck at a local tranny shop. It firmed up the shifts, but not to the point of snapping my neck. Towed the 5th wheel approximately 2,000 miles since then and am pleased. However, I am anxious to see how everything holds up when I add an Edge EZ to the mix in the Spring. As stated by others, for the cost, it seems to be a worthwhile band aid at least.
Old Oct 21, 2002 | 03:09 PM
98rammer's Avatar
[quote author=GONZO link=board=7;threadid=6069;start=0#55644 date=1035229010]<br>As DBR said, if you do not drill the seperator plate the shifts are firm and soft. I drilled the hole to the MAX and it slams the gears under hard acceleration, under light throttle it firm and a lil rough. Automatics in my old school racing philosophy should be harsh and fast......bam..bam..bam..gone. <br>[/quote]<br><br><br>alright, that's good to know. how long did it take you? what tools were involved?<br><br>1dslram -you have mail if someone hasn't beaten me to it.
Old Oct 21, 2002 | 03:15 PM
John_P's Avatar
GONZO:<br><br>Glad to hear the &quot;Trans-Go Shift Kit&quot; is working good<br>for you!<br><br>--------<br>Chris:<br><br>Yes, that is the same kit I had in my 96' and like<br>GONZO, I had VERY good luck with it!!<br><br>--------<br>John_P
Old Oct 21, 2002 | 04:15 PM
BigBlue's Avatar
Hey Gonz, nice to hear you have finally been bitten by the BOMBing bug. Now throw on some BD 5's, the Comp, a B-1, and go have some fun. ;D
