Timing issues after a new turbo
Old Mar 15, 2009 | 07:07 PM
kevellis32's Avatar
I just put on a super B special and I am wondering what everyone's opinion is to achieve a little better low end response. I know that this turbo is very laggy, but I have ridden in other trucks with the same turbo (24v's though) and it seems like they spool up a bit better. Any suggestions would be greatly appreciated.
Old Mar 15, 2009 | 10:57 PM
kevellis32's Avatar
Also, I am only able to get about 30lbs of boost out of the turbo right now and can't figure out why I can't get up to 40+lbs. I'm pretty sure I have enough fuel, but I could be wrong.
Old Mar 16, 2009 | 08:51 AM
kawi600's Avatar
The 12V doesnt flow as well without an aftermarket cam, but that shouldnt matter so much off the bottom.
You may benefit from fiddling with the AFC to add more fuel in the low end.
Is the turbo gated at 30? You can pressurize the system with an air compressor and see when the gate opens up.
wcbcruzer
Jul 22, 2011 05:25 PM
Warhawk22
May 16, 2010 11:43 PM
Teddy Bear
Mar 22, 2007 07:17 PM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
