Throttle Body Spacer
Old Feb 16, 2004 | 12:07 PM
TurboPirate24v's Avatar
I saw this in the Summit Catalog...for $99.00
Has anybody tried this ?
Is it hard to install ?
Any gains ?
Old Feb 16, 2004 | 12:11 PM
AlpineRAM's Avatar
Throttle body on a diesel ram ? Hmmmm didn't find one on mine.
AlpineRAM
Old Feb 16, 2004 | 12:13 PM
BigBlue's Avatar
I've seen this to. I'm kind of hesitant to spend my money on a crappy part. I've installed them on gassers before with great success. I'm not to sure bout a diesel though.
Old Feb 16, 2004 | 12:15 PM
Borush's Avatar
Was summit listing one for a Cummins? You won"t find a throttle body on these engines to put a spacer on.
Old Feb 16, 2004 | 12:18 PM
Check this out:
http://store.summitracing.com/defaul...spacer&x=0&y=0
PART: MVC-5116
or Direct Link:
http://store.summitracing.com/partde...art=MVC%2D5116
Old Feb 16, 2004 | 12:24 PM
Borush's Avatar
That must be for a 5.9 gas V8. It's not for a diesel.
Old Feb 16, 2004 | 12:25 PM
dakar's Avatar
Ah...there I see the problem, these aren't for our Cummins TD's... These are for the "Cummings diesel 4-valve."
Old Feb 16, 2004 | 12:41 PM
I called Summit and the sales rep has no idea why this there ... i.e., in the diesel section and states "NEW" for the 5.9 diesel ???
In sum...I feel dumb...thanks all
Old Feb 16, 2004 | 12:45 PM
Borush's Avatar
Nah...........sounds like the dummies are at Summit.
Old Feb 16, 2004 | 04:10 PM
farmer dave's Avatar
I have seen spacer for powerjokers, so maybe there is one aroud for a 5.9
dave
Old Feb 16, 2004 | 08:15 PM
Tartarus's Avatar
Saw the Cummins diesel throttle spacer in the Summit catalogue. E-mailed them a while back and asked.
It installs between the air horn and the heat grid block. It's got the little corkscrew cut into the aluminum, to "swirl" the air. That's what it does: swirl boosted air. Manufacturer claims 5 psi more boost, 2-4 more mpg, 20-30 more HP. No torque figures.
Swear-to-gosh.
That and a TAG, and I'll break a thousand horsepower.
Old Feb 17, 2004 | 02:57 PM
MCummings's Avatar
Darn, YOU TOO!?
I thought the group of 1,000HP TAG, TB spacers, Magnetic fuel lines, and Aeroturbine muffler users were sworn to secrecy?!
Now everybody is going to be catching up to me on the hills. I put some Banks stickers on to fool 'em, but now they know.
IS NOTHING SACRED?!
Merrick
Old Feb 17, 2004 | 03:25 PM
DF5152's Avatar
ok lets see i use the tag first to straighten the air flow then the throttle body spacer to swirl it again... im so confused. the primary job for these phenolic(sp) spaces on the gasers is th insulate the throttle body it also provides a space to increase runner length sometimes giving a little more low end. I would think you would be better off with insulating tape and taping everything from the air intake to the manifold.
Old Feb 17, 2004 | 03:52 PM
y-knot's Avatar
I just want someone to set-up and order the dang thing. I would but I still have the low tech 12V, and I recon it doesn't need to have it's air wiped around.
Old Feb 17, 2004 | 04:05 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Must be that Hemi-Diesel we keep hearing about.
Hey Jack, where did that thread go?
