Thoughts on PSC steering stabilizer brace
Old Jul 7, 2008 | 04:21 PM
sherpadad's Avatar
Originally Posted by kantdrive55
You shouldnt have to beat the bearing on. Ours has set screws to hold it once it is in place. It just slides on. Less than a 30 minute install from start to finish.
I had to a lot of peruasion (rubber mallet style) on mine too. It was not a slip fit.
Old Jul 12, 2008 | 01:58 PM
offroad's Avatar
I've got the PSC stabilizer and am very happy.
Construction appears first rate, best price I could find and it went on quickly. My bearing slid on the nose of the nut smoothly by hand. If you get one thats overly tight I'd make them send you another bearing and nut, you shouldn't have to beat it on.
Old Jul 12, 2008 | 07:35 PM
luke@ddp's Avatar
Ive got the BD Stabilizer on mine and love it.
Old Jul 12, 2008 | 08:08 PM
oaborbag's Avatar
major difference between psc and bd's? I think this will be my next upgrade as I can't stand my steering right now.
Old Jul 12, 2008 | 10:09 PM
wcbcruzer's Avatar
I'm also happy with my PSC stabilizer.
Old Jul 26, 2008 | 08:31 PM
CTD2001's Avatar
I got the PSC stabilzer installed today, Very simple install, though a second hand would be helpful when putting everything back together, a jack stand will work but another set of arms would be better. The hardest part was putting the bearing over the pitman shaft nut. It was not a "slip fit" as the direction say. I had to take a 1" socket and use that as a guid to beat the bearing up into place. I am very pleased with the results, it is a must do on these trucks. The steering is much tighter and tracks straight when i let my hands off the steering wheel, before it use to pull to the right. Anyone thinking about putting one of these units on there truck, do it, you will be amazed how it tighten things up.
Old Jul 26, 2008 | 10:22 PM
wcbcruzer's Avatar
My bearing went right on the shaft. It was a perfect fit. I also used my knee to hold the bracket up while bolting it in place (laying on my back).
Old Jul 27, 2008 | 07:55 PM
CTD2001's Avatar
yeah, that sway bar has more weight to it then i thought, its hard to hold it up there and line the holes up to put the new bolts in straight and not cross thread them
capt.Ron
Aug 17, 2009 10:57 AM
03CTDCO
May 20, 2009 06:36 AM
D45
30
Apr 17, 2008 07:24 PM
Chazmanian
25
Apr 8, 2008 08:57 AM
Buckshotram
Mar 8, 2008 12:58 PM
