For those with an Auto and have dyno'd
Old Jan 24, 2006 | 11:45 AM
gst mike's Avatar
I want to dyno my truck, how are you guys dyno'ing the auto?
Mike
Old Jan 24, 2006 | 11:59 AM
Eskimo's Avatar
Start at 55-ish in O/D and mat the throttle. With a 24V you won't go past the torque peak RPM before the turbo spools, and the torque convertor will stay locked.
Or, hook up a "mystery switch" and do it in third.... but read up before you do that.
Old Jan 24, 2006 | 02:41 PM
Mike D's Avatar
With an auto w/o a lock up switch you'll have to take it up till about 70 mph in O/D then lay the hammer. If you have a lock up switch, use the rpm gauge, once in lock up. I would say start at around 1200 rpm or so.
Old Jan 24, 2006 | 03:29 PM
Mcmopar's Avatar
Exactly, with the L/U switch you will probaly see a little higher number, more "time" for turbo spoolup.
Old Jan 24, 2006 | 04:23 PM
RowJ's Avatar
Mike
On a Dynojet Dyno- in overdrive/lockup... as described above.
On a Mustang Dyno - Do it in third, with OD locked out. Closer to 1:1 gear ratio and more acurate readings. Easier on the engine too, I think.
RJ
DRC8
Mar 1, 2008 11:28 AM
bigragu
Jan 25, 2008 12:37 AM
97CTD
Jul 29, 2007 08:22 AM
Box5
29
Mar 15, 2007 03:16 PM
Nuttymopar
Apr 25, 2003 02:17 AM
