thinking of minor mod
Old Nov 27, 2006 | 06:01 PM
2manykids's Avatar
Well, I'm thinking, If I don't sell my truck I might modify it slightly. What kind of "box" or modification can I install to get a little more power and better mileage? I always worry about loosing reliability with a modification. I don't necessarily need more power, but better fuel economy would be a plus. I've got 155k miles on my truck. Its totally stock and unmolested at this point. As far as I know, Its still the original lift pump too. And its an auto. My budget is pretty slim, so maybe there isn't a whole lot I can do.
Old Nov 27, 2006 | 06:06 PM
blackdiesel's Avatar
Registered
do you have gauges?
id look into the smarty. Its a real nice programmer...
Old Nov 27, 2006 | 06:13 PM
fourspeedracer's Avatar
I installed a Diablo Sport Power Puck its not as strong as some others . But I was not wanting something to cause me trouble like some hi powered boxes may cause. I really like it alot. It made the truck alot better. I got it from Summit it was only something like $205. Best money I sent on the truck so far.
Old Nov 27, 2006 | 06:14 PM
Beeram305's Avatar
You should be able to find an Edge EZ for real cheap on ebay or in the classifieds. Smarty is the way to go, but it might not be in your budget. Gauges are number 1 I think. Also, you could go with a juice/attitude that will give you gauges plus power for a good price if you can find a used unit.
Old Nov 27, 2006 | 06:15 PM
2manykids's Avatar
do you get any better mileage with the puck?
Old Nov 27, 2006 | 11:39 PM
Ph4tty's Avatar
Even on a tight budget you can get a bhaf (do a search) and remove the silencer ring so you can enjoy a little bit of whistle
I think you're on the right track with a timing box. Try the dtr classifieds for deals
Old Nov 28, 2006 | 12:38 AM
Marine's Avatar
Veteran: Marine Corp
I vote for the EZ. You don't realy need gauges for it, and it gives a great increase. I would get a low fuel pressure light, though, at the minimum.
Old Nov 28, 2006 | 05:55 PM
As far as mileage, have not checked it. I would say it has helped it a fuzz but you got to keep your foot out of the new found power...
Old Nov 28, 2006 | 06:10 PM
suzuki4life05's Avatar
how do u remove the silencer?
Old Nov 28, 2006 | 06:20 PM
DieselUnlimited's Avatar
Remove the intake tube form the turbo. Then remove the lock ring inside and remove the ring.
Old Nov 28, 2006 | 06:22 PM
thanks man
Old Nov 28, 2006 | 07:55 PM
jriggs_18's Avatar
The juice would be a good deal, or the smarty but be careful with either one, the tranny would be an expensive fix
blown32
Nov 3, 2009 10:23 PM
MrSuzuki
Aug 9, 2005 06:52 PM
wexman
Jan 1, 2005 10:02 AM
Haulin_in_Dixie
Oct 4, 2004 06:38 PM
RKCRWLR
Jul 31, 2003 02:11 PM
