Is there a "good" way to run a fuel pressure gauge?
Originally Posted by phox_mulder
That's ok, but how do you monitor it at WOT under load?
phox
phox
The two gauges I have now don't bounce around and the one I had before did not either. I use small resrictors I made and I loop the rubber lines around to kind of buffer the pulses and my fuel line is all rubber from front of tank to the VP.
I re-installed the fuel pressure gauge system using a pressure snubber at the VP 44 and a rubber line to a needle valve, from there it's plastic tubing to the gauge. No more leaks and no rattling gauge but the pressure snubber really takes away from the "responsiveness" of the pressure gauge readings. To better relate, it's like the gauge is filled with molasses now. It works, it doesn't rattle, and it doesn't leak so I'm now happy.
Originally Posted by Dr. Evil
It would be nice if you could share that part number and maybe help someone else out.
my issopro fuel pressure guage is leaking around the thread to the guage, what can I use to stop it?? i know i can't use teflon tape but is there a tape I could use so its not eat'n up by the diesel fuel
?? thx
?? thx
Permatex Number 2 or liquid teflon paste (Loctite) PST. In both cases make sure you clean the threads well (electronic parts cleaner will work)
?? thx
?? thxYou can use teflon tape, but it has to be the "yellow" fuel rated tape.
Teflon tape is for plumbing, not for vehicles, I don't recall ever seeing tape come stock on any vehical, think maybe there is a reason for this?
Use Permatex #2 or anti-seize for thread seal, easier to find than yellow tape anyway.
Originally Posted by infidel
Sure you can and it will be fine until you have to take something apart and can't get the tape debris out of female fittings without taking everything apart.
Thanks for the automotive/plumbing lesson. I've used the yellow tape without issue. As we all know, whatever comes stock on a vehicle must be the best solution....
Use what makes you feel comfortable!
