TC lockup again
Old Jan 28, 2009 | 08:54 PM
AlanF's Avatar
TC lockup again
I have over the years done the tinfoil around the alternator wire, cleaned up the ground wire and the DTT noise filter. I have rebuilt the trans with DTT parts about 20k ago. I just installed an adrenaline a couple weeks ago and the TC lock up spastic maneuver is back again. I am going to do a filter and fluid change tomorow and install a mystery switch. At least I should be able to force lock up when I am on the highway. While I have the pan off is there any sensor I can / should try to clean? Any suggestions for me.... I have had it with this transmission TC. Aargh.
Alan
Old Jan 29, 2009 | 07:31 AM
hic316's Avatar
Ever try adjusting the APPS?
Old Jan 29, 2009 | 07:34 AM
j-fox's Avatar
Check all the grounds again. Both ends!!
I found the cable on the passenger battery-engine end-was real loose on mine.
Old Jan 29, 2009 | 11:36 PM
AlanF's Avatar
fixed
While I was installing the TC switch, I made sure to remove and clean up my ground connections. I now have a mystery switch and a transmission which locks up as per normal. Do other vehicles with a lock up TC suffer the same type of issues with lock up control? I sure have had to fart around a lot over the years with this Chrysler system.
Alan
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
b84u
Feb 20, 2006 01:04 PM
