Swapped secondarys (super b in place of stock HX35)
Old Mar 22, 2009 | 04:55 PM
estrada5.9's Avatar
Got bored and swapped out my stock HX35 for a super b that I had laying around. My first reaction was how much slower it spools up now. Just went for a quick test drive a few O-70 pulls cause 5th gear is still out no money right now egt's didn't get above 1200 with boost at 60 before pegged my 1600* pyro with 65 psi but that was in fifth. I want to tow something now. Wastegate was set a 40 when I took it off. I am thinking about swapping back but ill wait until I get my tranny in so I can compare better.
Old Mar 22, 2009 | 05:00 PM
estrada5.9's Avatar
That Super b came off my 98 put a stocker on there holy moly I really got to hook up a wastegate on the thing. Forgot how quick HX35's spools a put my foot into it and it spools up to 45 in a flash yea i know hot air gonna explode etc etc. Just thought id throw this out there.
Old Mar 23, 2009 | 01:16 AM
Fishin2Deep4U's Avatar
What's the primary doing? Most likely the gate is way too tight on the secondary. This would explain the lower boost as the primary may not be getting full exhaust flow.
Dave
Old Mar 23, 2009 | 09:59 AM
estrada5.9's Avatar
Well what I found yesterday is the rod going to the wastegate arm lost its cotter pin so the wastegate was always open. Hmmm maybe this was what cause so much lag. I hope that it spools a little quicker now. With my old setup a had the afc so it wouldn't give it full fuel til ten psi I am goin to try and give it a little more sooner to see if that helps out.
Old Mar 23, 2009 | 11:44 AM
estrada5.9's Avatar
reconnected the wastegate back up. can't believe i didn't figure that out when I was driven it. spool up is really not to bad now. goin to leave it on there until a get my tranny fixed.
pvkj454
Jan 21, 2007 11:52 AM
PourinDiesel
May 1, 2006 06:15 PM
joefarmer
Aug 30, 2005 11:32 AM
2broke2smoke
Feb 5, 2005 07:42 PM
SjLingenfelter
29
May 17, 2004 10:40 PM
