Surging.
Old Apr 9, 2009 | 08:47 PM
ramsport59's Avatar
Surging.
Hey Guys, I've noticed over the last couple days with the Edge Juice on any level, When I try to get on it hard, it Surges, pulls hard for 2 secs, backdowns and surges again. Its like the power is kicking on and off. It doesnt do it with the Edge Off. I've had a problem like this before, but **** if I can't remember what I did. I wanna say the screw for the VP44 Stealth Cover wasnt getting a good contact. No codes, or alerts from the edge.
Thoughts?
Rick
Old Apr 9, 2009 | 08:49 PM
Iroc's Avatar
Do you have a fuel pressure gauge?, are you using a stock lift pump. SOunds linke your running out of fuel to me.
Old Apr 9, 2009 | 08:56 PM
ramsport59's Avatar
Sure Do, running Holley Blue with 21psi at idle and Wideopen 14psi.
Rick
Old Apr 9, 2009 | 10:40 PM
Dglass89's Avatar
edge might be gettin burnt up
Old Apr 9, 2009 | 11:57 PM
HotRodTodd's Avatar
Bad MAP/Superboost sensor or the connections on the plugs at the sensor have become loose or coroded.
Old Apr 10, 2009 | 08:18 AM
clarson80's Avatar
^^^^^ x2, map sensor.....
Mine is doing exactly what you just explained, finally threw a code the other day...map sensor-low voltage.
Called local napa...the guy said it wasn't available anymore?? Didn't believe him, but didn't feel like arguing with him.
Called local Cummins dealer....he wouldn't even look the part up, just said " nope, dealer only part"....didn't believe him either (should have looked the part # up on this forum before calling so he would've had to order me one)
I found this link on here and ordered one for a great price: http://http://hoeslidiesel.com/store/page5.html
Old Apr 10, 2009 | 09:11 AM
Mike Holmen's Avatar
The Guru
What boost does it do the surging at? You running a stack programmer/box?
Its probably the air intake temp sensor. You could try to pull it out and clean it with carb cleaner. I thought about just putting in a constant restistor/toggle switch and get rid of that variable.
You must have some lazy a$$ parts stores. Cummins and NAPA both??? Wow.
Old Apr 10, 2009 | 03:08 PM
clarson80's Avatar
It will surge around about 9-12lbs....doesn't seem to matter if the xzt+ is on or off. (no stack, just the quad box)
It even started to idle a little high once in a while- about 950-1000. Shut it off and restart, idles fine. I think I might pick up a IAT sensor too.
yeah, the local cummins dealer here doesn't really seem to want to help out dodge guys, just OTR trucks, very frustrating.
Old Apr 10, 2009 | 05:34 PM
ramsport59's Avatar
Figured it out....Loose jam nut on the VP44 Stealth Cover Tap.
All is good now!
Thanks guys for the input!
Rick
dodgeram
Jul 23, 2003 09:43 AM
bkay
Apr 16, 2003 02:49 PM
bkay
Apr 7, 2003 09:08 AM
Voss
Feb 17, 2003 07:33 AM
toolmaker
0
Nov 23, 2002 07:27 AM
