superflow dyno #s
superflow dyno #s
Superflow dyno #s
Well just got back from dynoing the beast. I ran several times 8 to say the least. My best #s to date is 662.9 @2200rpms and 1632.6ftlbs @2100rpms with 3.8% tire slippage. Those #s were backed up several runs that were close together. My best valet run was 451.9 @2200 thru 2600rpms and 1125.1 ftlbs @2000 rpms. All runs are with diesel only. The water meth pump went south on me! My valet run yeilded 48 psi boost and 1175 degrees. The full fuel run yeilded 62 psi and just touched 1550 to 1575 degrees. The down side is i am out of fuel. (need more fuel capitain)!! I did have a issue running. I had to light foot it untill 55 mph and then roll into it hard. I believe that if i was able to roll into it at a lower rpm with out the trans shifting down to 2nd the #s would have been higher. Well the quest for more power moves forward! If i can figure how to scan and put the graphs on here i will do it. I did get to see a pumped up mustang run. 190 hp and 154ftlbs.
My runs were all with a custom cut plate, 191 dvs, 4 k kit, modified afc control, Lennys stage 4s, fass system and a rack end cap plug. Pump is timed at 20 degrees. I would like to thank Rob @ PDR for building my tranny to handle the power.
Great numbers, sounds like you need some laser cut dv's though
Of course I dont know what I'm doing with these silly p-pumps
Edit: Thats an awesome torque to power ratio too!
CoolumConst
May 24, 2008 06:24 PM
pwerwagn
Feb 28, 2007 03:18 AM
Bluedeviltorque
Feb 28, 2006 05:26 PM
502502
23
Nov 23, 2005 06:16 PM
Mike S
Feb 11, 2005 10:28 PM
