Superchips Boost Fooler Power Increase
Old Jun 20, 2007 | 08:54 PM
evan4434's Avatar
I have a 2002 HO with a six speed. Will a boost fooler and boost elbow increase my power and lower my egts, or is this even need with a superchip?
Is anyone running a superchip and a boost fooler and elbow now?
Old Jun 20, 2007 | 11:41 PM
B-Peterson's Avatar
yes Iam I dont think the superchip dose any boost fooling.
Old Jun 21, 2007 | 12:04 AM
Ph4tty's Avatar
More boost should cool you down and allow you to run bigger sticks for more power =P More boost doesn't necessarily mean more power unless you have fuel.
Old Jun 21, 2007 | 07:23 AM
hamilton71801's Avatar
I can hit 28psi of boost with my boost fooler/j hook pulling big grades.
Old Jun 21, 2007 | 11:33 AM
evan4434's Avatar
How high of boost do you get with just the superchip and J-Hook and boost fooler. What egts are you seeing. Are they lower with the J-Hook and boost fooler?
Old Jun 21, 2007 | 12:36 PM
I've never seen anymore than 28psi with or without the SC. When I tow, I just turn the darn thing off and go back to the stock setting (of course I have my injectors) and can hit 28psi when I'm in the peddle. My highest EGT when running the SC on tow perf(before injectors install) was 1180 degrees pulling my #7000 TT in July on a long grade. As far as the difference with/without the j-hook, I did my gauges at the same time as I did the j-hook so I can't help you out there.
Old Jun 22, 2007 | 08:35 AM
pmtg's Avatar
the j-hook wont do you any good as you have a manual tranny...need a boost elbow or manual boost controller.
sCreamin400
25
May 10, 2010 10:14 PM
jrgreene1968
0
Mar 3, 2009 06:44 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
jmccart
Apr 10, 2007 08:32 PM
jmccart
Mar 26, 2007 09:12 PM
