Superchip Tuner w/comp Question
Old Oct 20, 2007 | 11:21 PM
SMOKNISB's Avatar
I installed my guages and Comp tonight. I put on an Isspro Pyro, fuel pressure, and boost guage. I already had a tranny temp. I also wired the Comp up and removed the Superchips. Got it done in about 3 hrs. Everything is working great. The comp is awesome. One question though, anyone know if I can just use the Superchips to tune for tire size? Or do I have to load one of the performance programs? If so, would I be alright running the lowest Superchips program with the comp?
Old Oct 21, 2007 | 12:46 AM
J Lent's Avatar
I ran a superchips programmer version 1.0 stacked with my comp for a while, the stack worked well, but the engine rattled alot. The Superchips went bad & froze up, but it froze up before changing my tire size back to stock. sent it to Superchips & they sent me back the tuner with the new software version 1.10 which didn't work well at all. I'd just sell the superchips & forget it.
Old Oct 21, 2007 | 07:09 AM
SMOKNISB's Avatar
Well I really just want it for the tire size adjustment and for the code reader.
Old Oct 21, 2007 | 08:55 AM
J Lent's Avatar
I have a friend who had the same scenario & he did something crazy. He adjusted his programmer back to stock & unplugged it before it could adjust tire size back to stock. I am not recommending to do this, but it did work on his truck. The Superchips does its programming in steps, first loads the program then adjust tire size second.
Old Oct 21, 2007 | 11:57 AM
Mike Holmen's Avatar
The Guru
When I stack my comp box and the superchip all I got has problems. I tried running every program, with the box wire tapped/not tapped. The problem is that superchip advances the pump and so does the comp box. The smarty is a better stack. Today, I have no clue where my superchip programer is. You might be going down that road as well. I think that programmer lead to the slow death of my ecm. Once I tired to put that program in and the programmer crashed, my ecm never work right again. It could also been a bad ecm but who can prove that. Good luck, you might have different luck with the stack, as some trucks like it some don't. Mine didn't.
Old Oct 22, 2007 | 10:44 PM
J Lent's Avatar
I bet your programmer had version 1.10 instead of 1.0, but Smarty is by far the best stack with the comp & it does adjust tire sizes also.
Old Oct 22, 2007 | 10:54 PM
one54ton's Avatar
drag comp is all you need
Old Oct 23, 2007 | 10:12 AM
SMOKNISB's Avatar
yeah but you cant adjust for tire size on the comp. I love the comp though.
Old Oct 23, 2007 | 01:38 PM
MikeR's Avatar
Just go to the dealer and have them adjust the tire size
Old Oct 23, 2007 | 04:51 PM
SMOKNISB's Avatar
Anyone know how much that runs?
Old Oct 23, 2007 | 05:37 PM
Jturs's Avatar
they might charge you a half hour labor or more, roughly 90$ per hour, even though it takes about 5 minutes tops. depending on how nice the service advisor is they might just do it for free. they did it for free at the other dealership i worked out. just call and ask.
Old Oct 23, 2007 | 09:24 PM
SMOKNISB's Avatar
Well I have decided to sell the Superchips on Ebay if anyone is interested.
TorqueJunkie
Nov 10, 2006 09:12 PM
ramman21921
May 9, 2006 11:02 AM
2500TurboDodge
Jan 18, 2006 08:59 PM
king d
Jan 5, 2006 06:34 PM
