Superchip or Smarty?
Old Jul 29, 2006 | 03:32 PM
Crazy Horse's Avatar
Smarty vs Superchip info wanted:
Recently had a dead pedal incident w a code 0500 with extremely high temps here in SC. I pulled the VA Plu n Power off the truck and reinstalled my void sticker thinking I may have a fuel LP or VP problem. I thought may be between the heat and the fact the VA PnP has been on 2 different trucks since 2000 it may getting tired. Cleared the code and have been driving stock with no problems except low power.
Road test w/ the vulcan fuel pressure guage today and fuel pressures seem to be normal for stock. 12 psi idle, 9psi cruising 40-50 mph in the hills, and between 6 & 7 psi WOT.
So I've been thinking of something different like Supchips plug in or the Smarty. The both will recalibrate the speedo for the oversized 285's recently installed. It appears they both add approx the same HP. What are your expriences with the Superchip and the Smarty?
Old Jul 29, 2006 | 04:14 PM
Charlie8301's Avatar
The smarty is in a league of its own. All the non-wire tap boxes add about the same hp, but none of them fuel on the low end like the smarty.
Randy
Old Jul 29, 2006 | 04:52 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yep no comparison, Smarty all the way!
Old Jul 29, 2006 | 06:24 PM
Cmullen's Avatar
i have an '06 and i am waiting for the smarty Marco rules.....
Old Jul 29, 2006 | 07:56 PM
BigBlue's Avatar
Comparing superchips to a smarty is like comparing 4 karat diamond ring to a cracker jack ring. They both may be round and have a sparkling thingy on it but when you give your girl the real thing is when it truly shows it's value. Same with the smarty. It may add the same power and look the same as the superchips but when you hook the smarty up to your truck it's like giving your girl that 4 karat diamond. BIG DIFFERENCE in the response.
Old Jul 29, 2006 | 08:06 PM
Bob Wagner's Avatar
Chris 06 smarty first 1/2 of september. most all of Italy shutsdown for all of august.
parts for the 06 trucks will be available after the vacation shutdown
Old Jul 30, 2006 | 12:21 AM
displacedtexan's Avatar
So now you are the expert on the ladies?
Old Jul 30, 2006 | 03:09 AM
BigBlue's Avatar
No. I just know how to get on their good sides.
Old Jul 30, 2006 | 09:58 AM
Well I ordered a Smarty last night. That was the way I leaning before I opened this thread, plus I did more reading on the subject.
I'm sure it's probably in the directions but how easy is it to set the parameters back to stock or adjust the different power levels? It looks like you just hook it up to the OBD port, every time you want to change and select "stock" or other power options. Where as the old VA PnP was on all the time.
Thanks for your help.
Old Jul 30, 2006 | 11:01 AM
BigBlue's Avatar
You got it. Turn the key to ON but don't start the truck, plug the smarty into the OBD port, push the buttons. Very, very, very simple. Takes all of about 1.5 minutes to load a program.
Old Jul 30, 2006 | 11:07 AM
12valveford's Avatar
just wondering for the old man's '05
he already has a Edge juice w/ attitude
is the smarty stackable with it?
what would the out come be?
Old Jul 30, 2006 | 11:30 AM
BigBlue's Avatar
Yes it's stackable and it should be a very nasty combination.
Old Jul 30, 2006 | 07:12 PM
is that a good nasty or a bad nasty
Old Jul 30, 2006 | 07:28 PM
Good for him. Nasty for those that mess with him
Old Jul 30, 2006 | 07:31 PM
DMcPherson's Avatar
they should work very well with other boxes. I just ordered mine to go with the comp
