Stumped
Old Mar 26, 2007 | 10:22 PM
gtstrkd's Avatar
Stumped
Ok guys I bought my truck used about 1 1/2 years ago and cant figure out what kind of work it has done to it. It runs way better than what any stock cummins I have ever rode in and every time I try to add a box it sounds like it has way to much timing. Any ideas?
Old Mar 26, 2007 | 10:33 PM
smknram's Avatar
fill out you signature and tell us what you got
Old Mar 26, 2007 | 10:42 PM
Tate's Avatar
Check for connections under the hood. Boxes like the VA will plug into the harness of the VP. Others like the Edge will hook into the Data link port (triangular or a flat 3 prong connection, depending upon year). Also check the MAP sensor at the back of the head. There may be a harness hooked into it, which will be a dead giveaway. Other option would be a tuner or swaped ECM.
gtstrkd's Avatar
Its filled out I dont know why it show. 02 3500 cab and chassis 6 speed intake gauges and straight piped
Old Mar 26, 2007 | 10:50 PM
gtstrkd's Avatar
Checked all of that. Put a superchips programmer on and the motor was extremely noisy like too much timing. Is there any way to find out if the ecm was swapped for a catcher or a mad
Old Mar 28, 2007 | 09:01 AM
01smoker's Avatar
I would try and get ahold of the previous owner(s). They should be able to give you an answer.
Old Mar 28, 2007 | 09:04 AM
Mike D's Avatar
If you had a MAD ECM you would know it. It would smoke pretty good off boost.
Old Mar 28, 2007 | 12:37 PM
displacedtexan's Avatar
How much boost can you get? How about smoke?
Old Mar 28, 2007 | 09:53 PM
gtstrkd's Avatar
I can hit about out 21 pounds and it throws a pretty good cloud of smoke. It looks like it has the factory boost elbow I just havent got around to getting a block off or an adjustable elbow.
Old Mar 28, 2007 | 09:54 PM
gtstrkd's Avatar
I can hit 1250 pretty easy and it seems like from all of the other post that my cruise temp is a little higher than most at about 800-850
Old Mar 29, 2007 | 12:32 AM
Ph4tty's Avatar
It doesn't explain the timing rattle, but maybe you have some aftermarket injectors?
Old Mar 29, 2007 | 01:29 AM
Big Blue24's Avatar
Sounds to me like you either have a smarty tune, or more likely bigger injectors like Ph4tty said. I'll bet you either got some RV 275's or some Jammer 2's. Both smoke pretty good with stock ecm tuning pushing them. Does it cut out when the boost comes up? If not, i'd lean more towards some sort of special tune. If it does cut out a little around 20-22 psi boost, most definately just injectors.
Old Mar 29, 2007 | 07:26 PM
gtstrkd's Avatar
No cut out but it falls on its face at higher rpm's if that helps any. Would it sound like too much timing if it had a set of injectors?
Old Mar 30, 2007 | 12:20 AM
Ph4tty's Avatar
If it quits pulling at 2700 then thats a stock ecm not a mad ecm aka the catcher/ smarty programming. It is possible it was flashed with a superchips or some other programmer in which case you could get the ecm reflashed by the dealership or a smarty owner,...... or you can just go with it and look for fueling boxes instead of timing/ fueling boxes =P
If you pulled an injector there's people on the dtr that might be able to tell you which one it is =P
Old Mar 30, 2007 | 06:36 PM
gtstrkd's Avatar
thanks for your help guys. When i get back home i will take some time to pull an injector.
