Studs/Firerings??
Old Jul 11, 2007 | 11:05 PM
Awall's Avatar
Studs/Firerings??
At what point are head studs/ o-rings req'd?? Because i am thinking about a turbo and injectors... Thanks in advance - A.Wall
Old Jul 11, 2007 | 11:19 PM
oaborbag's Avatar
Some people say as soon as you upgrade your turbo, others say once u go over 45 or 50 psi, but then there are those people running close to 60 psi with neither done, A lot of people will probably reply better safe than sorry and to get it done, I'm not an expert, but seen quite a few posts about topics close to this
Old Jul 11, 2007 | 11:24 PM
Awall's Avatar
yea i heard 50 psi was aobut where ya wanted to do it.... better safe than sorry. I've been told i could do small injectors and not ahve to getta new big turbo, but i was thinking if was gonne do it lets do it right and go for the power but i aint got that much $ floatin around haha
rockjeep73's Avatar
what do you plan on getting for a turbo and injectors?
Old Jul 11, 2007 | 11:27 PM
Awall's Avatar
Ain't really sure yet.. havent researched it that much bc i lack the funds... I was thinking maybe Mach 5 injectors or an equivalent, not sure what the best turbo match would be... also are the 12 or 14 mm ARP studs recommended?
Old Jul 11, 2007 | 11:56 PM
rockjeep73's Avatar
12mm studs is all you will need.
Old Jul 12, 2007 | 12:00 AM
Awall's Avatar
Whats a good turbo/injector setup if looking for most power up to req'ring O-rings?? (cant afford the firerings /port and polish)
Old Jul 12, 2007 | 12:22 AM
Muddin_dude06's Avatar
If I was to go back to when I first bought my truck studs would have been #2 with gauges #1...
Old Jul 12, 2007 | 02:51 AM
Ph4tty's Avatar
So what is considered safe for studs and the stock gasket?
Old Jul 12, 2007 | 07:42 AM
BCB's Avatar
BCB
I am pushing up to 60 PSI on stock head bolts and a stock gasket and it has held for almost a year now. although i know i am on barrowed time. as for injectors and a Turbo i would call Doug at PDW and tell him what you are after and see what he says.
leeboy
Dec 22, 2014 09:48 AM
77machomopar
Nov 30, 2009 11:55 PM
1BadDzl
Jan 6, 2004 07:04 PM
Copenhagenjunkie
Dec 18, 2003 03:17 PM
Battering Ram
Apr 10, 2003 09:12 PM
