Steering Satbilizer
I've got the skyjacker dual setup on mine ............... I like it
Part Number 7218 , they call it a steering damper kit
install instructions
I had the Skyjacker set-up on mine and really liked it. It helped a lot with the 35's I was running especially in loose stuff.
No steering stabilizer dual or otherwise is going to cure the dreaded death wobble. It may help some, but not fix it.
Matt
Matt
Like said above, death wobble wont go away with a steering stabilizer... Death wobble is usually caused by a worn trac-bar, tie-rods, bad alignment or even unbalanced tires...all stabilizers do is mask problems in the steering.
Now as far as single or dual stabilizers go, Ive run both...with 33", 36" and 38" tires...and IMHO, I think they don't make much of a difference. If your steering is set up correctly, then you shouldnt need one. If its just one of those things that makes you feel better, dont waste money on a dual kit...its a waste. A single is fine. Im running 38" tires right now and no stabilizer at all and the truck drives just fine everywhere. I used to be under the impression that I needed them, but they kept getting bashed on the trail, so I just ditched them all together and havent missed them since...been running without one for more than a year.
I've got a dual set-up from Skyjacker; replaced the stock stabilizer after 9K miles. 30K on the truck now.
On normal road surfaces, the dual doesn't make a difference. However, it helps alot at higher speeds on dirt and pot-holed roads, or roads with raised seams and worn ruts in the asphalt.
Is it worth it? For the kind of driving I do, absolutely. Your kind of driving? Who knows?
Originally posted by Stamey
I have heard that a dual is no better than a single aftermarket stabilizer. Anyone had experience with BOTH and can offer their input?
Chris
Chris
Originally posted by rattle_rattle
I see that you have a 2002 also. The application guide only shows up to 2001. What part number did you use?
I'll emphasize -- if you're driving on normal road surfaces, it won't make a difference. Don't waste your money. It's largely an off-road/bad road item.
LanceK
13
Jul 14, 2006 08:08 PM
ocsurf16
Mar 13, 2006 09:24 PM
unioncreek
Jun 29, 2005 02:00 PM
OHFarmboy
Feb 25, 2005 11:30 AM
Jun 5, 2003 09:27 PM
